coolant leak at right rear side of engine. - Ford Truck Enthusiasts Forums
Old 01-29-2008, 06:21 PM
TEKWS01 TEKWS01 is offline
TEKWS01 is starting off with a positive reputation.
Question coolant leak at right rear side of engine.
I have a 2000 ,f150, 2wd,5.4.
There is a small coolant leak near the right rear head. I have found a
tsb 00-18-3. Bulletin indicated that this is caused by a intake manifold gasket and can be fixed by ordering yl3z-9439-aa gasket. I was wondering if anyone else has experienced this before?
Old 01-29-2008, 07:51 PM
yankee7985 yankee7985 is offline
yankee7985 is starting off with a positive reputation.
It could also be you cylinder head.
Old 01-30-2008, 12:03 PM
ssanto ssanto is offline
ssanto is starting off with a positive reputation.
I've had a similar leak, but it wasn't the cylinder head.
By right side you mean passenger side, right?
There is a tube that goes into the intake manifold towards the back of the engine on the passenger side. This tube feeds hot coolant to the heater core. On my truck the tube developed a pinhole leak. I googled it and read that the same thing had happened to a few other people.
Since you have to remove the intake manifold to fix it, I went another route... I ended up glopping on EPOXY and letting it dry and then repeating a few times to seal it up. Worked like a charm.
Not sure if this is your problem or not, but its worth looking into to see exactly where the leak is coming from.
Old 01-30-2008, 06:03 PM
tj90 tj90 is offline
tj90 is starting off with a positive reputation.
Quote:
Originally Posted by ssanto
...Since you have to remove the intake manifold to fix it, I went another route... I ended up glopping on EPOXY and letting it dry and then repeating a few times to seal it up. Worked like a charm.
Man I love JB weld! I used it on a thermostat housing and it held for 100k miles saving me about 100 bucks.
Old 01-30-2008, 06:08 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
heater hose fittings them selfs have been known to leak and drip coolant onto the back couple spark plugs-- you might check the hoses and fittings.
Old 02-06-2008, 01:32 PM
I wanted to give update.. the replacement gasket solved the coolant leak and solved my #4 missfire.. coolant had filled up my spark plug tunnel.. thanks all for the input.
1995 F250 coolant leak Breezland 1987 - 1996 F150 & Larger F-Series Trucks 3 01-15-2014 10:30 PM
coolant leak around pulley johnf2507.3L Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 08-11-2013 01:16 PM
How Much $ to Replace Head Gaskets? Forest 6.0L Power Stroke Diesel 20 01-09-2008 11:22 PM
Coolant Leak!!! TexasGuy001 1987 - 1996 F150 & Larger F-Series Trucks 12 02-25-2004 10:14 AM
1996 Ford Explorer Coolant leak donhclark Explorer, Sport Trac, Mountaineer & Aviator 6 05-23-2003 02:11 PM
Tags
2002, 99, antifreeze, coolant, engine, expedition, f150, ford, jb, leak, leaking, rear, supercrew, top, weld
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
