i got a dilema i found a deal on a 94 f150 lifted on 33s , 6 inch lift so he says, the truck is in another state im in maryland so i hered that i will have to reinspect the truck even know that he told me he passed inspection, and that the lift will make the truck fail inspection BLAHH, so wut are my options besides taking the lift off, i need info on this guys if u been in this dumb situaition, help is greatly apreciated
I passed NJ inspection with 36's on stock suspension. Umm if you ask some private inspection places if they would over look the lift. It wouldnt be worth taking the lift off. Have you looked up ur state rules about lifts?
If all brake lines 9Including em's r lower or lengthen and lift install looks neat. It may pass in PA . I say may because I know of 2 station who will not do it now. They r getting clamped down on. Good luck
yea that the problem the truck i want is in new jersey and i live in maryland and the more i think if i run into problems with gettting it to passs in our state
im an a lisenced inspector in NH and the lift law here is basically how hig off the ground your frame is. i forget the actual height but its something like 30" give or take..haven't inspected an off road truck in a while. if it is just the bumper height or frame height they are concerned about then get the stock tires for your truck. that will lower the overall height but a lot depending on what tire you put on to replace your current ones. then take it to get inspected, and when its done and passed, put the bigger tires on. that way they can't fail you for a being to high and it covers there *** too. good luck
Just wait till Ole Crist trys his "...cleaner Florida..." He's coasing up with Arnold in kaliforina right now.... I have bad feeling about this! Here in Southwest Fla, tall trucks are all over the place and some people I know never had problems(so far) with major lifts.
