Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 12-27-2001, 05:54 PM
cr_ford cr_ford is offline
Garage is empty, add now
cr_ford is starting off with a positive reputation.
1999 F150 Airbag Light
The airbag light on my 1999 F150 recently started to blink a code 27 when started. It is followed by the light being on constantly after the pattern is repeated. Also the passenger side switch does not react according to the manual. Any help is appreciated...
  #2 (permalink)
Old 01-13-2002, 12:31 PM
OhioRiverFordMan OhioRiverFordMan is offline
OhioRiverFordMan is starting off with a positive reputation.
My '99 airbag light started coming on around the middle of December... it flashes the code 32. I had a mechanic look it up and it refers to a open cicuit on the driver's side bag.
Mine doesn't come on all the time... sometime I hit a good size bump and it comes on, other times I can just be going down the highway and it starts flashing... and sometimes it comes on when I start the truck... go figure.
  #3 (permalink)
Old 01-18-2002, 07:25 PM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
  #4 (permalink)
Old 01-19-2002, 05:53 PM
gyyr gyyr is offline
gyyr is starting off with a positive reputation.
Post 1999 F150 Airbag Light
I have also had the same problem with my 99 F150 flashing 27. Im still trying to figure out what the problem is.
  #5 (permalink)
Old 01-22-2002, 06:56 PM
I wanted to update everyone and let you know that I resolved the problem. The problem turned out to be a burned out light bulb. The bulb is the one that indicates the passenger side bag is off. The bulb is soldered in a circuit board with a few resistors and a magnetic reed switch. Ford dosen't sell the bulb by itself and wanted $70.00 for the assembly. I substituted the bulb with an LED and currrent limiting resistor in serious. Think I used a 1K resistor.
CR
Tags
1997, 1998, 1999, 2000, 2005, 32, air, airbag, bag, code, f150, flashes, ford, light, stays
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
