95-97 F250 7.3 - nuts to buy one?
Hey Guys,
I'm considering buying a 95-97 F250 CREW and wanted some feedback from you guys as to whether I was nuts for going this route. Basically I'm looking for a reasonable cost 4-door truck, so I can go older (95-97) or pay a lot more and go newer (2004-2005 F150).
What are your thoughts on the life of a 7.3? If for some reason the 7.3 needed to be rebuilt, what's the average cost for this?
Mind you, I wouldn't consider buying an 95-97 unless it was very well taken care of.
Thoushts?
CMOS
Thoushts?
CMOS
on
These trucks and engine are great! No reason not to buy on as long as it has been taken care of. high miles aren't a great concern as long as maintence has been done all long. Rebuild costs for the engine depends on whether you do the work or somebody else does the work. Rebuild kits with pistons, oil pump and all other bearings, rings, ans gaskets are about $950 then any machine work. You would have between $1000 (hone and go) -$2000 (bore the cylinders and head refresh w/labor) If some body else has to pull the motor and do the work you could be looking at another $1000-1500.
But as stated many of these engines don't need rebuilding for a long time
I wouldnt say you're nuts at all...
in fact, i just bought one. its a 96, and it was taken care of better than any other truck i've ever seen. it starts, runs and shuts down better than most of the 01's or 02's i was testing. it has 260k miles on it, still has all the power, comfort, towing capability... you get my point. just make sure you get one that has been well taken care of.
Dan
Dan
If your handy with wrenches and want to have some fun get one! Had an '87 2 door and went to a '96 4 door. love 'em. I just worked thru some issues with mine. These guys will help you solve almost any problem that comes up if you've got the sticktoitiveness. Keep an eye on tranny service if it's an auto. I opted for a manual to dodge that bullet. They go a long time if the engine oil is kept clean and full.
I am planning on something near that year in a crew cab when I finally need a new truck. Right now I am have a 97 ext cab that just turned over 189K and still running strong. I bought it w/ 9000 miles on it in 1997. I towed a 87 ext cab w/ 6.9 this past weekend to Camp Lejune NC from Augusta Ga and averaged better than 14.5 mpg. I figure that was close to 13000-14000 lbs total including my truck.
If you find a clean one jump on it, sure bets 500.00 a month for a new one.
Originally Posted by saltydog452
For those who responded with a positive answer, do you have manual transmissions?...if so, OEM clutch and dual mass flywheel?
Thanks,
salty.
Thanks,
salty.
you should be able to find a good one for 7-8k i would expect.
