Has anyone used 252 , 260 High Energy Cam from Comp Cams? - Ford Truck Enthusiasts Forums
Old 10-19-2001, 04:17 PM
Superdave Superdave is offline
Superdave is starting off with a positive reputation.
I was wanting to know if anyone has used the Comp Cams. 252 or the 260 High Energy Cam in their 460? I was on their web-site looking around and these seemed like a decent choice of camshaft for a stock 460.
Thanks, Superdave
94 Ford Aerostar XL 3.0L
82 Ford F250 4x4 XLT,400 CID,C-6 A/T,8700lb GVWR. Black & Silver
Old 10-20-2001, 07:38 AM
DeenHylton DeenHylton is offline
DeenHylton is starting off with a positive reputation.
I installed a Comp 268 cam in a 1978 F250 w/460 and it was too much cam for an auotmatic with a 3:55 rear gear...you'd just be getting into the powerband when the trans would shift. In high gear you'd need to be around 70-75 MPH to be in the low end of the powerband, which is faster than most of us normally drive. I would have been better off with the 260 cam. If you have a stick and a 4:11 gear with stock tire size than the 268 maybe the way to go. As far as the Comp 252 cam goes their catolouge recommends it for a "medium size engine" (300"-350"). Soooooooooooo I'd go with the 260. Deen
Deen Hylton
Ford F250 460 C-6, K&N, Headers, Dual Exh.,Comp. Cams,Shift Kit
Pioneer CD w/Bose Speakers.
Other Passion: Blown 77 Corvette (Sorry Guys/Gals)
How I can afford to Drive the above: 93 GEO Metro
Old 10-24-2001, 12:17 AM
bigsnag's Avatar
bigsnag bigsnag is offline
bigsnag is new and has a neutral reputation at this point.
I've got a 268H in a F-150 with 3.25 gears and a C6 with a stock converter. It's just fine. My engine is no where near stock, but the power is there from idle to out past 5000. My C6 shifts when the tach hits about 5200 now. Because tachs lag a little, the engine is probably turning 5300-5350. Contrary to popular belief, you CAN adjust WOT shifts with an adjustable vacuum modulator. I did.
Old 10-24-2001, 02:54 AM
Thanks for the replies. I was thinking in the line of the 260 High Energy, from what I read on their site. Still would like to hear if anyone has used it.
Superdave
Old 10-25-2001, 07:44 PM
mavman mavman is offline
mavman is starting off with a positive reputation.
had one in the "first" 460...it was ok, I mean I thought it was kind of dead all the way across the powerband, but that might've been because it was 7.9:1 compression. I guess it depends on what else has been done to the engine, like headers, intake, carb, compression ratio, etc, etc. If you havent figured it out, 460's love lots of cam/carb/big headers. There's a lot of cubic inches to feed, but if you have an otherwise stock engine, the 260 should be make pretty nice torque.
Old 10-28-2001, 11:12 PM
compman's Avatar
compman compman is offline
compman is starting off with a positive reputation.
My best friends dad (a hardcore ford nut for sure ) ran the HE260 in a '73 429 in his '78 F-150. The engine was .040 over with flat tops (right at 9.0-1)...otherwise bone stock for a '73 429 other than the dual 2 1/4" exhaust. 2.75 gears, 235/75/15's, and a shift kit. Very smooth idle, instant throttle response, but it didnt feel much stronger than with the stock cam. It did get 2 mpg better economy though according to him.
Old 10-29-2001, 11:21 AM
busdriver1 busdriver1 is offline
busdriver1 is starting off with a positive reputation.
Comp 252 and 260 cam opinions 351Cleveland C4 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 21 05-12-2014 04:49 PM
what cam for a 4.9 with speed density blue924.9 1987 - 1996 F150 & Larger F-Series Trucks 9 11-19-2013 07:08 PM
Cam selection for the 300 custom1106 Ford Inline Six, 200, 250, 4.9L / 300 24 04-04-2012 03:46 PM
Any one using a Summit cam, Part #SUM-K3500 in your 460? Superdave Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 16 10-02-2003 12:31 AM
Anyone a Comp Cam High Energy 260H Cam. proeliator FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 02-19-2002 08:57 PM
Tags
252, 260, 260h, 268, 460, cam, cams, cams252, comp, enegy, energy, engery, high, reviews, torq, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
