Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids and Mileage
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #16 (permalink)
Old 02-29-2008, 11:48 AM
bucks77ford's Avatar
We will rise again
bucks77ford is gaining momentum as a positive member of FTE.bucks77ford is gaining momentum as a positive member of FTE.
Not my original plan, but I will be running my 521 street stroker in 77 F250 4x4 with E85. I have 10:1 compression with my current cam and I don't want to have to get a bigger cam to run pump gas, so I'm going with an E85 750 CFM carb. I will be very curious to see what kind of performance I get and how much ethanol it will burn.
__________________
BUCK
"My mind works like lightning, one brilliant flash and it's gone"
1977 F250 4x4 Highboy-Frame Off Restoration in Progress
  #17 (permalink)
Old 02-29-2008, 04:31 PM
FordTrucksKickGM is starting off with a positive reputation.
When will your 521 be up and running? Im curious to know how it comes out. Im gettin close to ordering my 545 rotating assembly and Ive been tossin around the idea of gettin between 10-10.5 CR to run E85.
  #18 (permalink)
Old 02-29-2008, 07:39 PM
We will rise again
I hoping to have it at least built to dyno this spring. As far as running in the truck, probably not til fall. Hopefully, sooner, but you know how truck projects are.
__________________
BUCK
  #19 (permalink)
Old 03-09-2008, 08:20 PM
BobsF350 is starting off with a positive reputation.
the only way E85 works out to your benefit is if its 3/4 the price of gas.thats the effiency difference .on a flex fuel vehicle if you get 20MPG on gas youll get 15 on e85
  #20 (permalink)
Old 03-11-2008, 03:55 AM
We will rise again
I don't plan on getting very good mileage at all. I wouldn't with gasoline either. I just want to be able to run my street motor without having to add Octane booster or Racing Fuel. Ethanol is a nice alternative for higher compression street engines.
__________________
BUCK
  #21 (permalink)
Old 03-11-2008, 10:42 PM
Dino@his Dad's is starting off with a positive reputation.
not quite...
Bob, efficiency burning ethanol isn't as simple as counting BTUs per gallon. You are quite correct that ethanol has about 2/3 rds of the BTUs per gallon of gasoline, but there is more to it than that. Ethanol also has a much faster flame speed than gasoline, AND a wider limit of flammability. How the fuel map on a flex fuel car is programmed makes a huge differance in what fuel mileage you will get. One of the fellows on an E85 forum has his car running just fine on a 16.8 fuel ratio........I'll bet he isn't losing 1/3 of his potential mileage. DinosaurFan, on work's old cast off 'puter
  #22 (permalink)
Old 03-11-2008, 10:59 PM
wedefyu's Avatar
wedefyu is starting off with a positive reputation.
The biggest benefit without a doubt of E85, is it's abbility to resist detonation, pricewise compared to race gas. Where I live, a gallon of E85 is 2.55 or so and has an octane rating of 105 (summer blends anyway), and race gas is 6-7 a gallon. So run a Quickfuel 750 E85 carb and 12:1, it will be fun.
__________________
Josh
79 F'150 302 NP435/205
79 Bronco 400M/NP203
67 F100 352 Auto 2wd
72 F100 302 Auto 2wd
  #23 (permalink)
Old 04-12-2008, 09:29 AM
White Shadow is starting off with a positive reputation.
Polish Premium
Most of my buds who want more power with thier chips with out burning expensive pump premium use what we call POLISH PREMIUM. As you can tell, South Bend area has a heavy Polish population and it is a term of endearment-not a cutdown. Anyway, they simply put in a 50/50 mix of regular 87 octane gas, and E85-which results in about a 93 octane rating-and this is a conservative rating. I use this mix in my 97 Escort with a chip and love it. No pinging here, it has 127,000 miles on it and have been using this mix for 20,000 miles. Also, if you search other threads you'll find I've been running my truck on e85 for over 50,000 miles with stock injectors, fuel lines, pump ect...and had no trouble. I do have a custom tuned chip tuned for E85 though. But if you use a 50/50 blend, you could use your premium fuel setting on your tuner and the PCM should have enough latitude to compensate.
__________________
E85 powered 2003 F150 4.2 stick
2003 Focus
1997 Escort
1966 Jeep Gladiator Pickup
  #24 (permalink)
Old 04-24-2008, 09:19 AM
MisterCMK's Avatar
MisterCMK is a name known to allMisterCMK is a name known to allMisterCMK is a name known to allMisterCMK is a name known to allMisterCMK is a name known to allMisterCMK is a name known to all
Quote:
Originally Posted by Allch Chcar View Post
Basically accurate, ethanol is corrosive whereas gasoline is oily and bears some lubricants.
Hmm, gasoline is corrosive as well....
__________________
Chris
1994 Mustang GT
1992 Explorer XLT
2000 Expedition EB
Quote:
Originally Posted by tcbofade
I have no brain
  #25 (permalink)
Old 04-29-2008, 02:29 PM
99F150 is starting off with a positive reputation.
I have a Diablo Sport two tune chip in my 99 Ranger with 2.5L and 5speed. One tune is for E85. My E85 MPG is good in city but poor on highway due to open loop over 80% throttle. I plan to have it retuned to keep engine in closed loop even at full throttle.
As it is I can break even at $.58 spread in price.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
