You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
HELP!
I recently dropped a 352 in my truck and it's got bad bearings and low oil pressure once it warms up. I'm not ready to give up on my restore project yet though I look at this as a minor but expensive set back. I've never rebuilt an engine before but, look forward to learnig. I've already put a lot of work into this truck and have grown attatched to it. If I can find a reliable motor in my budget I will probably consider that first. I'm not looking to build a hot rod I just want a good running pick up. I've even considered dropping a 300 6 cylinder in it. I live in lynnwood, if anyone knows of someone in that area I could talk to about motors or some work I would really appreciate it.
Thanks
There are different ways you can go, depending on how much money and how much time you are willing to spend.
- Find a working motor, and drop it in yourself, or with help Would be cheapest
- Buy a remanufactured...Would cost and take your time, but more reliable than the above.
- Go to a mechanic and have him drop in a remanufactured... Probably the best bet, if you want something reliable, and do not do the work.
- Blueprint the motor and do it yourself...This woud be the choice if you want to learn the process... Is expensive, because you will have to depend on a machine shop and buy the parts. Not to mention the time involved in putting it together and dropping it in.
This is the option I chose, but the machine shop work was about 1600, the parts amounted to about 5000. Note: I did make it a performance motor with parts from Summit, and I had the motor balanced. Not to mention a Holley 4160 750 cfm and Edlebrock intake combo for the supply. There were a few other non motor things I invested in, but the bottom line was it ran me about 9500 to put a '85 302 in a '68 F100...That does not even count the hours that I put in.
Heck, I only paid 500 for the truck, and it was running.
Good Luck!...Projects are fun, but can cost a bit.
__________________ "I wear my own kind of hat" (Merle Haggard)
EClampus Vitus Major WM Downie 1849
A 300-6 would be a different bell housing-
You can get 360s and 390s off Craigslist for under $500. I've been shopping for one lately, but my budget is a bit below that, and a bit below what I have found any for.
__________________
Jared
Real trucks have the key on the left FTE Guidelines
