All y'all MAF conversion gurus. A9 vs. truck ECM
on
Originally Posted by stangbanger
Can these S/D ford trucks be modified somewhat without needeing maf"? just surious i know the mustangs have their own s/d cams and what not. But can mild head porting, and s/d cams, and some intake work be done without problem?
on
The Stang computer probabaly has too much advance for a heavy truck, something that can be cured with a MAF tweak or a tuner/chip. http://www.mass-air.com/Products.htm
Originally Posted by mudgepondexpress
Weird, I have a 1986 SEFI engine in my 81 F150 with the stock AOD. I am running the A9L (auto one I believe) with stock Mustang MAF and it has had -0- ping issues. I towed a stock car for a few summers, use it to haul everything and it has never had an issue.
Kenny
Kenny
Kenny
Kenny
[QUOTE=Conanski]The Stang computer probabaly has too much advance for a heavy truck, something that can be cured with a MAF tweak or a tuner/chip. http://www.mass-air.com/Products.htm[/QUOTE]
What is a MAF tweak??
Also, you use the Mustang computer from the FMS kit (the same as me) AND you have your base timing set to 18 degrees if I remember correctly. That said, how are you gettng away with SO MUCH advance (the computer with an aggresive tune w/ a large amount of base timing) with your heavy truck?
on
[QUOTE=eco]
It's the air adjuster thing on that site..
Here's my theory.. which I'm gonna soon prove or disprove as I have a Tweecer RT on the way.
First off I'm giving some credit to the heads on this motor, I have worked over E6's which have that kidney bean shaped combustion chamber that produces a swirl motion in the air/fuel mixture. They really do that.. as evidenced by the deposit patterns on spark plugs from this motor. Instead of the carbon being evenly distributed over the whole end of the plug, it tends to be more on 1 side indicating a definite flow pattern. I also cleaned up these combustion chambers and removed all sharp edges and casting defects, so these heads should be about as detonation resistant as it gets.
Second.. the motor is 357 cubic inches and the computer is calibrated for 302. Because this motor moves more air than a 5.0 the computer interprets this as a 5.0 under heavier load and backs out the ignition advance more than it normally would at any given rpm.
If this is correct then as soon as I change the engine size to the right number in the computer tables, the engine load calculations will return to the normal range and I will have to back off the initial advance to prevent detonation.
What is a MAF tweak???
on
How does the air adjuster allow for more advance? As I understand it, I don't have one yet but this weekend I will order one, all it does is raise or lower the signal that the MAF sends to the computer so that you can tamper with the air fuel ratio to compensate for things like injector size and the other things that the site lists.
on
Originally Posted by TheRoadVirus
I thought the Tweecer RT only came for MAF applications? (mustang?) Is there one for an SD style truck? I would prefer to keep the MAP and all that but the bank injection is definitely something I don't like..
Oh, where would I find a Tweecer RT for a SD setup if one exists?
#29
on
ok when you say tuner you guys mean handheld tuner? Or can a dyno guy go in and put a chip in it and custom tune my s/d computer?
-Randy
-Randy
#30
To answer the original question, you'll find that the Mustang EEC's are more universally supported by PC-based tuning software and hardware dongles - simply because it's more common for a mustang owner to seriously upgrade their powertrains moreso than the ford truck crowd, and tune accordingly. Mostly because people race Mustangs more often than pickups
Since the wiring differences between Mustang EEC and Truck EEC aren't that radical, a small amount of wiring-related pain up front pays off big when you have 20 questions related to tuning and 100 people can answer you on various forums on the internet in minutes.
I personally like Paul Booth's free "EECTUNER" software for the PC combined with Craig Moates J3 Adapter set. Including various adapters, a USB eeprom programmer you're into Mustang EEC tuning in about 10 minutes for about $100 or thereabouts.
Both guys are incredibly helpful as well. EECTuner supports any EEC that there is an associated BIN file, and both Paul and Craig have a collection of them. You can make your own BIN as well once you have the tuning knowledge and understanding of a particular EEC - you're not locked into Mustang bits with the Booth/Moates stuff.
Tweecer which was recommended above is also an excellent package, and slightly easier to install. Plug in cable, plug in laptop, boot software. I'm not sure of the pricing at the moment but several years ago when I got into EEC's (and away from GM ECM stuff) Tweecer was more than double the price, but a bit more plug and play.
I *strongly* urge you to tune rather than "lie" to your EEC. There are many MAF rescaler products as well as EGR bypass as well as other sensor bypass kits available, and from experience I have to tell you that using those devices make tuning the EEC more complicated, and rarely is the outcome anywhere near as good as tuning the EEC directly for your application, whether it be naturally aspirated or forced induction (supercharger, turbocharger).
Enjoy!
Enjoy!
