360/390????
360/390????
someone gave me a 390. it was left out in the rain for who know how long. but anyway as i getting the engine freed up. i measured the bore and it read 4.06" with .030 stamped on the pistons. is this engine basically a 360?
i orginally took the engine cuz i needed a new crank for my 390, seeing the hash marks in the rear main seal area. leaks like there is no tomorrow.
Originally Posted by f2501967
i have replace the rear main seal 2 times. and looking at the other block i just got and there are no hash marks in the rear main seal area, on the crank
Some reverse rotation marine cranks have the oil helix (slash, hash marks) going the opposite direction. That said there is a recent thread on FE.com about marine cranks. Someone mentioned there was a marine crank version with no helix marks used after 66. I found that interesting. But I've never personally seen one. And have had the pleasure of tearing down my share of marine 427's. I've also seen guys smooth them out but that leaves the journal undersize and leaks like crazy!!! You need to grind, weld and machine smooth back to oem specs to do this properly. And then use a neoprene seal instead of rope. You can check the crank for a JE in the casting number which denotes a marine crank. Reverse rotation cranks used either a C5JE-B or C6JE-D casting number. Also as mentioned one of the plugs in the rear of the block could be weeping under pressure. Early blocks used press in cup plugs and are prone to leaking. Later plugs were threaded plugs which are the way to go. Being your not seeing the helix marks you might wanna measure the dia of that journal to see if it's undersize. If so that's probably the problem. The helix marks are sometimes hard to see if your doing this with the engine in the truck. But you can run your fingernail on the journal and feel for them. Also check FE.com for that thread. Might give you some further info and insight. Good luck. Some of those oil leaks are a bitch to find and correct. I've had some engines no matter what I did were just seepers and leakers. Others were fine. LOL.
G.
G.
.... i measured the bore and it read 4.06" with .030 stamped on the pistons. is this engine basically a 360?
i orginally took the engine cuz i needed a new crank for my 390...
--Mike
alfuson
06-03-2009 11:10 PM
1975 f150 360
16
01-18-2009 11:04 PM
61 uni
09-30-2004 06:33 PM
76 F250 4X4
12-21-2003 06:41 AM
penn
19
03-29-2003 07:17 PM
