Overdrive Light Blinking????
on
Welcome to the forum. The next thing that will be fried is your trans if you are not monitoring the temps..I get nervous of temps over 210*. Another cause for the blinking light is the VSS sensor on top of your rear end.. Mine was bad last year and i replaced it with a Napa p/n 530780 (napa calls it a ABS sensor).. easy to install... $10.49
About a day after my light started blinking my truck had a real hard time shifting from 2nd to 3rd. had the code read and sure enough it was slipping. Oil smelt burnt and was real dirty. I was pulling a trailer up in the mtns when the light started blinking.....
Had the oil changed and so far it is running ok....
Originally Posted by Slug
I'm new to this forum and I had my overdrive light blinking along with the speedo falling off to 0 mph. Transmission was cold and after 2 or 3 min. it stopped blinking and the mph started working again. Haven't had this happen again. Any comments?
Welcome to FTE.
Originally Posted by Smokin'
Why only the 01? I'm wondering what the difference was between the '01, and the 99, 00, 02, 03, etc?
I'm sure I just screwd your mine up with this stupid stuff I just wrote, but thats what I know.
