I have a van that I resently put soy diesel into and 200 miles later the van stalled I changed the fuel filter and the cps and blead the heads and the van will run on either but wont run by itself, when the motor is cranks fuel will flow from the heads but the thing will not start
did you bleed fuel or oil at the heads. Also for future reference it isn't neccesary to bleed it. it will fill and run with out it. Do you have a wait to start light? any smoke out the tail pipe? Also do what plowhand said and check the PCM/fuel heater fuse.
