Oil & Lubrication
2001 F-150 Rear End Gear Lube
Old 01-28-2008, 07:36 PM
otter 1's Avatar
otter 1
otter 1 is offline
I had my rear end completly replaced on my 01 F-150 Crew Cab with 62000 miles on it. The specks say to use a 75-140 Syn gear lub wich they did Valveoline VV 982 lube. This afternoon I had a mech. tell me that he used to work at a Ford Dealership and that they had some problems with the 00 & 01 rear ends useing the syn lube and they had went back to the 90W gear lube without any problems. Has anyone heard of this takeing place? The rear end was a 355 if that's any help. Thanks for any help or insite you might give.
Old 01-29-2008, 09:11 AM
jimandmandy's Avatar
jimandmandy
jimandmandy is offline
I havent heard of problems with the Sterling/Ford differentials, but it is possible. I had a 93 GM 8.875 that started seeping from the pinion seal as soon as I changed to syn, but it had dino as factory fill. Toyota uses dino in limited slip units, but syn in the open ones.
Jim
Old 01-29-2008, 10:03 AM
BrianA's Avatar
BrianA
BrianA is offline
I had the rear end open on my '05 a few months, (about 10,000 miles) back.
Same rear end as your truck.
I used a house brand from a local inependent shop.
Something or other Synthetic 75-140. It seems to be working perfectly.
Assuming you have an open diff, I suspect you'll be fine.
The guy you talked to mentioned "problems". Did he elaborate?
Leaking?
Nosie?
Bearing failure?
Gear wear?
Thanks.
Old 01-29-2008, 11:38 AM
otter 1's Avatar
otter 1
otter 1 is offline
He mentioned about noise and gear wear. On mine, the diff bearings were starting to pit, plus the gears were wearing, and the reason I noticed it was it seemed to be making quite a bit of noise (howling) from what sounded like the back end. After I replaced everything brand new (Ford) which was under extended warranty I can't hear any noise what so ever. The thing is if it calls for syn. lube thats what I would like to use. Just wondering if anyone else had heard of that type of problem.
bigcountry1009
1999 to 2016 Super Duty
10-27-2014 08:37 AM
BadDogKuzz
01-10-2011 05:06 AM
satx77stepside
Oil & Lubrication
10-23-2005 01:08 AM
just_brian
Oil & Lubrication
09-10-2003 03:21 PM
just_brian
08-21-2003 08:01 PM
Quick Reply: 2001 F-150 Rear End Gear Lube
