Go Back   Ford Truck Enthusiasts Forums > Misc. > Oil & Lubrication
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Oil & Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
SPONSORED BY:
  #1 (permalink)
Old 01-28-2008, 07:36 PM
otter 1 otter 1 is offline
Garage is empty, add now
otter 1 is starting off with a positive reputation.
2001 F-150 Rear End Gear Lube
I had my rear end completly replaced on my 01 F-150 Crew Cab with 62000 miles on it. The specks say to use a 75-140 Syn gear lub wich they did Valveoline VV 982 lube. This afternoon I had a mech. tell me that he used to work at a Ford Dealership and that they had some problems with the 00 & 01 rear ends useing the syn lube and they had went back to the 90W gear lube without any problems. Has anyone heard of this takeing place? The rear end was a 355 if that's any help. Thanks for any help or insite you might give.
  #2 (permalink)
Old 01-29-2008, 09:11 AM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
I havent heard of problems with the Sterling/Ford differentials, but it is possible. I had a 93 GM 8.875 that started seeping from the pinion seal as soon as I changed to syn, but it had dino as factory fill. Toyota uses dino in limited slip units, but syn in the open ones.
Jim
  #3 (permalink)
Old 01-29-2008, 10:03 AM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.
I had the rear end open on my '05 a few months, (about 10,000 miles) back.
Same rear end as your truck.
I used a house brand from a local inependent shop.
Something or other Synthetic 75-140. It seems to be working perfectly.
Assuming you have an open diff, I suspect you'll be fine.
The guy you talked to mentioned "problems". Did he elaborate?
Leaking?
Nosie?
Bearing failure?
Gear wear?
Thanks.
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
  #4 (permalink)
Old 01-29-2008, 11:38 AM
He mentioned about noise and gear wear. On mine, the diff bearings were starting to pit, plus the gears were wearing, and the reason I noticed it was it seemed to be making quite a bit of noise (howling) from what sounded like the back end. After I replaced everything brand new (Ford) which was under extended warranty I can't hear any noise what so ever. The thing is if it calls for syn. lube thats what I would like to use. Just wondering if anyone else had heard of that type of problem.
Tags
150, 2001, 2003, 2004, axial, end, f150, ford, gear, gears, lube, lubricate, oil, rear, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
