Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-05-2001, 05:10 PM
tbolt 460's Avatar
tbolt 460 tbolt 460 is offline
tbolt 460 is starting off with a positive reputation.
460 Blocks
what is the reason for the cylinders being longer(6 1/4) in a D9TE block and 6in in a D1VE block??Which is the HD block?Which one to build up??Thanks
__________________
88 BII(208,000mi still going) chop project
90 BII,2.9/C5/D44/9in
86 Ranger Xcab STX 4X4,D35,8.8,456's locked,4in lift
94 Xlporer sport
95 Ranger short bed 4X4 4.0 5spd
http://rangerdave.freeforums.org/
  #2 (permalink)
Old 11-05-2001, 11:49 PM
Superdave Superdave is offline
Superdave is starting off with a positive reputation.
460 Blocks
I assume you are talking about the bore height from the bottom of the bore to the top of the block. It may be because of where Ford increased the deck height of the block to decrease the compression ratio from the early 460's on to the newer ones. I don't know. According to a book I have, the deck height was increased from 10.300 inches to 10.322 inches. Between this and increasing the cc's in the heads they dropped the compression from 10.5:1 to 8.5:1
Superdave
94 Ford Aerostar XL 3.0L
82 Ford F250 4x4 XLT,400 CID,C-6 A/T,8700lb GVWR. Black & Silver
__________________
Superdave
2000 Superduty Lariat, Extended Cab 4x4, 5.4L
  #3 (permalink)
Old 11-06-2001, 03:00 AM
ludis ludis is offline
ludis is starting off with a positive reputation.
460 Blocks
Longer cylinder bores provide more support for the piston. This keeps the piston more squarely in the cylinder at the bottom of the stroke. This should reduce wear during high power conditions.
Ludis
  #4 (permalink)
Old 11-06-2001, 09:00 AM
classic79's Avatar
classic79 classic79 is offline
classic79 is starting off with a positive reputation.
460 Blocks
__________________
Chris
79 F-150 Lariat 460 C6
88 LSC
79 Mustang: 460
Tags
460 , block , blocks , d1ve , deck , ford , height , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
