I just posted yesturday and had my van just stall I put new fuel filter in it and a new cps and it still nothing, It will run on either but not by itself. We took the plugs loose on the back of the heads and when we cranked the motor it then would push fuel through there but not when the key was turned on. we have been reading the books about this and still have not victory
98 ford 3-350
7.3 power stroke
359,000 miles
thanks for your help
when you turn key on fuel pump should run about 15 seconds to build pressure
does it do that?
when you open fuel drain on filter with key on do you have a good flow of fuel
how are the batteries?
__________________ Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install
DooDad???=(dfuser ram air)
'98 Grand Cherokee
'86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
The batteries are new and the fuel pump is mechanical or at least that is what I have found by talking to people and calling the parts guy
I am at a total lose here I have no idea what to do now
Are you getting any smoke out of the exhaust when cranking? My old mans 96 wouldnt start because the oil reserve for the Heui system was low so it didnt have enough to fire the injectors.
Yes this van all are fine I went to advance auto and according to them this was built right before they used electric fuel pump my has a maniacal pump. We looked up and down the frame and found no fuel pump
