Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #31 (permalink)
Old 02-02-2008, 04:06 PM
IDMooseMan's Avatar
IDMooseMan is gaining momentum as a positive member of FTE.
The Fuel Pressure Regulator (FPR) should have a schrader valve (like a bicycle tire) on it. Screw on a fuel pressure gauge to the schrader valve and start the engine. The needle will probably jump up and down. Watch where the low and high readings are and go with the middle reading as a starting point.
If you don't get a reading of at least 60psi at idle, the FPR may need adjusting. In the 94.5 - 97 thread, we call it an "FPR Shim". Go to our thread and search on "FPR Shim". You'll get plenty of reading material and info (with pictures) to do this.
Basically, we added a BB to increase spring tension. This brings the fuel pressure into spec.
As an example, my '97 F350 had a pressure reading of about 40psi. I added a BB to the FPR. The fuel pressure raised to 70psi. The engine idles smoother and throttle response is fantastic.
I bought a fuel pressure gauge from NAPA. It says to not use it for diesel. It isn't permanently connected to my truck, so I didn't worry about it. It screws onto the schrader valve and reads fine. Get the 90* adapter if there isn't alot of room.
DO NOT ADD THE BB WITHOUT KNOWING "BEFORE" YOUR FUEL PRESSURE. TOO MUCH FUEL PRESSURE IS NOT GOOD.
__________________
Craig "IDMooseMan" Peters
1997 F-350 XLT 4x4 CC LB E4OD 4.10:1
FPR Shimmed to 70 PSI, 6637 Upgrade, ICP Resistance Mod, DiamondEye 3" Downpipe and 4" Exhaust
USAF SSgt 1983 - 1992
NAHC Life Member
1991 Wilderness 24M
Sponsored Links
To remove this ad, register today!
  #32 (permalink)
Old 02-02-2008, 04:55 PM
George D.'s Avatar
George D. is starting off with a positive reputation.
Quote:
Originally Posted by IDMooseMan
My '97 7.3-liter PSD requires a minimum of 40psi and a maximum of 80psi at the FPR. The closer to 80psi, the better.
Did you check the cable connections at the battery, starter relay and the starter? If they're loose, the starter won't engage and the engine won't turn over.
I think the fule presure is less witha michanicle lift pump like he has could be wrong though
__________________
94 F350 Crew Cab Long bed 4X4 7.3L IDI Factory Turbo, AKA The Land Yacht. E4OD, 4.10 posi. Getting further from stock with 35 inch BFG alterains on 16 inch micky's, straight pipe, Triple A-piller pod with pyro, boost, modifyed stock oil presure gauge, tc lock light&switch
  #33 (permalink)
Old 02-02-2008, 05:01 PM
IDMooseMan's Avatar
My engine has a mechanical fuel pump.
__________________
NAHC Life Member
1991 Wilderness 24M
  #34 (permalink)
Old 02-02-2008, 05:08 PM
james_phebe is starting off with a positive reputation.
George D I don't understand what your reply means
I looked again and have no fuel pump and no relay for that
  #35 (permalink)
Old 02-02-2008, 05:46 PM
George D.'s Avatar
Guess I was wrong sorry.
__________________
  #36 (permalink)
Old 02-02-2008, 06:43 PM
i didn't mean to offend you. I was just wondering about your text.
  #37 (permalink)
Old 02-02-2008, 07:28 PM
George D.'s Avatar
Not offended I was refering to IDMooseMan saying he had a mechanicle lift pump I was wrong about the psi needed to start. I thought he had an electric pump but you both have mechanicle lift pumps.
__________________
  #38 (permalink)
Old 02-02-2008, 10:56 PM
do you have an idea on what i should do? I am at the point of trying to find a shop that can try to fix it in the area. I am also hearing that the soy diesel can toast injectors do you know anything about that?
  #39 (permalink)
Old 02-02-2008, 11:01 PM
We have a wise Int shop about 30 min from us but they charged my boss 1400 for a glow plug and a transfer fuel pump on our 1999 INt box truck, that just scares me to death I don't have that kind of money. I also don't want to take it to a shop who is just guessing at what the problem is.
  #40 (permalink)
Old 02-02-2008, 11:29 PM
George D.'s Avatar
I would call first and get them to give you some kind of quote for diagnosing it and to see it they'll even work on a non fleet vehile some IH dealers will some wont. But the labor rate is pretty high the IH dealer I work at is $105 an hour. You may want to see if theres any small shops near you that could look at it they may be cheaper but may not know what there doing but the IH dealer may not either. But it also may cost you more in buying tools to check it out than to have it fixed of coures you'd have the tools for next time.
As for the soy fule as I understand it bio is no bueno in the navistar counterparts and kills warenty on injectors and such.
And if the box truck had the T444E the lift pump is bitch to get too and I think pays like 3 hours pluss parts. and depending on the setup and what side the glow plug was on theres a bit of stuff in the way but 1400 seems kinda steep.
__________________
  #41 (permalink)
Old 02-02-2008, 11:44 PM
thanks I will do some calling on monday I will let you know what happens thanks for all your help James
  #42 (permalink)
Old 02-02-2008, 11:57 PM
George D.'s Avatar
Just had a thought Do you have oil presure when cranking?
__________________
  #43 (permalink)
Old 02-03-2008, 03:46 PM
yes it takes it 2 or 3 cranks but it climbs all the way up to 3/4 the way up
  #44 (permalink)
Old 02-03-2008, 04:06 PM
rbaker6336's Avatar
rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.
Quote:
still sounds electrical,check here http://arrc.epnet.com/autoasp/framerq.asp for a diagram on top right you will see three fuses,two relays and a diode that can control fuel
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install
DooDad???=(dfuser ram air)
'98 Grand Cherokee
'86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
  #45 (permalink)
Old 02-03-2008, 04:32 PM
Hi it says I need a password and a user name what should i put in that location my email is james_phebe@yahoo.com
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
