Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 01-29-2008, 10:02 PM
George D.'s Avatar
George D. is starting off with a positive reputation.
Check you're fule presure think it should be like 35psi.
__________________
94 F350 Crew Cab Long bed 4X4 7.3L IDI Factory Turbo, AKA The Land Yacht. E4OD, 4.10 posi. Getting further from stock with 35 inch BFG alterains on 16 inch micky's, straight pipe, Triple A-piller pod with pyro, boost, modifyed stock oil presure gauge, tc lock light&switch
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
james_phebe is starting off with a positive reputation.
Yes the glow plugs are working fine we have the van inside a shop with it plugged in for the last few days at least since it went in there. HPOP how do you know if it has enough oil in it? Is it like in the valley of the motor like in front of the fuel filter. I have been tring to find a picture but that is has been harder than I thought.
Thanks for all the help by the way
  #18 (permalink)
Old 01-29-2008, 10:04 PM
I thought of putting a new fuel pump on just to rule it out. How do you check that with a mechanical pump
  #19 (permalink)
Old 01-29-2008, 10:17 PM
rbaker6336's Avatar
rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.
yes right in front of fuel filter
you will find a plug on top
remove plug and oil should be within 3/4" from top
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install
DooDad???=(dfuser ram air)
'98 Grand Cherokee
'86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
  #20 (permalink)
Old 01-29-2008, 10:39 PM
George D.'s Avatar
There should be a shrader valve on the filter head. hook a fule presure gauge too it and crank it . I wouldn't go changing that pump just too rule it out its a pain to get too.
__________________
  #21 (permalink)
Old 01-29-2008, 11:04 PM
Hi I went down and found the box and pulled the sensor thing and inserted a small screwdriver and the oil was almost 1/2 inch from the top.
  #22 (permalink)
Old 01-29-2008, 11:06 PM
I am totally at my minds end with this thing I have been trying everything and nothing at least on my 6.5 the computer tells you something is wrong this thing thinks everything is ok
  #23 (permalink)
Old 01-29-2008, 11:12 PM
rbaker6336's Avatar
one thing you might try,there is a sensor (IPS) toward front of left head,unplug it and see if there is a difference,this puts injector control pressure at default
the computer you checked codes with,was the software for powerstroke
most software and scanners won't pull codes on a PSD
__________________
Ray
'98 Grand Cherokee
PAA #35
  #24 (permalink)
Old 01-29-2008, 11:20 PM
The computer is from MAC tools and i am not sure if it directly for a power stoke
What would that mean if that thing is unplugged? What is a IPS
I will try
  #25 (permalink)
Old 01-29-2008, 11:31 PM
rbaker6336's Avatar
I will try
if the sensor is bad it can cause a no start,unpluging will just set pressure to default
the IPS detects high oil pressure
BTW I would ask if the scanner had software for powerstroke
__________________
Ray
'98 Grand Cherokee
PAA #35
  #26 (permalink)
Old 01-30-2008, 01:15 AM
George D.'s Avatar
Yeah if you unplug the ICP, injection control presure sensor on the front of the driverside head, it should throw the IPR, injection presure regulator into a default seting. The MAC scanner should have, key word should, the stuff for reading powerstrokes but may not pluss wouldn't be so sure the guys at autozone fully understand how to use them alot of the scaners that do multiple vehicles can be quite confuseing. and they may have just checked generic obd2 codes wich wont tell you anyting usefull for you're problem.
__________________
  #27 (permalink)
Old 02-02-2008, 02:09 PM
I checked all of the fuses again and switched the relays around and now the stupid think wont even turn the starter over. I looked for the sensor on the front of the dr side head and could not find it
  #28 (permalink)
Old 02-02-2008, 02:24 PM
rbaker6336's Avatar
sounds like you may have a bad relay and and just moved it to another spot
__________________
Ray
'98 Grand Cherokee
PAA #35
  #29 (permalink)
Old 02-02-2008, 02:43 PM
IDMooseMan's Avatar
IDMooseMan is gaining momentum as a positive member of FTE.
Quote:
My '97 7.3-liter PSD requires a minimum of 40psi and a maximum of 80psi at the FPR. The closer to 80psi, the better.
Did you check the cable connections at the battery, starter relay and the starter? If they're loose, the starter won't engage and the engine won't turn over.
__________________
Craig "IDMooseMan" Peters
1997 F-350 XLT 4x4 CC LB E4OD 4.10:1
FPR Shimmed to 70 PSI, 6637 Upgrade, ICP Resistance Mod, DiamondEye 3" Downpipe and 4" Exhaust
USAF SSgt 1983 - 1992
NAHC Life Member
1991 Wilderness 24M
  #30 (permalink)
Old 02-02-2008, 03:20 PM
yes I just checked the starter and the battery cables and all are tight. I moved the relays back around to where they were and still nothing, how do you check the fuel pressure on a van? Do you know of a good machanic near northern Indiana? I am just to the point of cleaning this thing out and sending it to the junkyard. I have never been so frustrated with something in my life.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
