Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-28-2008, 06:15 PM
Bushwhacker1 is starting off with a positive reputation.
Intermittent Coil Problems
Truck is a 2000, F150 super cab long box, 4.6l with 160000km (100,000 miles)I first experienced the miss when on my way to go moose hunting, loaded pulling a trailer over hilly highway. It would start to miss climbing the hills and the Check Engine light would flash. When I got home, by the time I got to a Ford mechanic, the codes had cleared. He changed the plugs (which I had already done within the last few months) and discovered that 4 of the coils were cracked. He told me to return when I experienced the miss again. I did, and he changed one coil. The problem went away until about 2 weeks later, when I was on my way to deer camp. I stopped by his shop, but he wasn't in yet. He had told me that if I could get it scanned closer to home, to see which coil was missing, he could change it. I did, but their scanner just said "coil misfire", maybe their technoloby wasn't up to the task. Now it hasn't done it since, but I am sure the next time I haul a heavy load it will. The price on Ford coils is $120Cdn, but aftermarket are from about $85 up. Are replacement coils as subject to cracking as the originals? Is there any good reason to buy the more expensive coils, especially since I will replace three?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-30-2008, 07:23 AM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
Got to www.summitracing.com and order a set of Accel coils. They are anly about $29 US each. If they are cracked, then they are going to continue to cause problems. Especially under a heavy load or high humidity.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #3 (permalink)
Old 01-31-2008, 10:15 AM
Bobcat7 is starting off with a positive reputation.
Or try rpmoutlet.com I got out the door for around 200 for all eight. accel. Have been running fine.
  #4 (permalink)
Old 01-31-2008, 02:03 PM
wtroger is starting off with a positive reputation.
$100 dollar bill ebay gets all 8 delivered to the door. They don't say motorcraft on them and they are not made in the USA. But neither are the high dollar ones.
  #5 (permalink)
Old 02-02-2008, 08:32 AM
LxMan1's Avatar
Motorcraft are, I make the body and the bobbin that the winding goes around here in Ky.
Visteon actually makes them for Ford after we mold the plastic parts in them.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #6 (permalink)
Old 02-02-2008, 07:42 PM
When the msrp on a cop is $93.00 versus $12.00 I think I will try the $12.00 dollar one first.
  #7 (permalink)
Old 02-02-2008, 08:38 PM
earthrover15 is starting off with a positive reputation.
howdy y'all
a little help here would be much appreciated thanks
1998 ford 4X4 4.6 L new reman long block from ford, new plugs, wires,pcv & usual when doing engine swap. Runs great all day till you find gentle grade in high gear then at about1600 rpm an intermittent stutter or misfire occurs. If no movement of throttle hesitation stays, with more throttle misfire goes away. No cel or any other indications of anything wrong. coils are from original motor with 124000miles on them any help here would be wonderful! What is a computer reflash? Thanks again
btw it's not unAmerican to drive foreign gas miser cars. I have 83 pulsar that gets 37 mpg on freeway granted it's not as quick as my vette but it's great for errands and stuff
take care and don't be a pedal masher....
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
