Heater not working...
Old 01-28-2008, 03:57 PM
AKtruck's Avatar
AKtruck
AKtruck is offline
My wife has a 97 ford explorer V8 awd that had the heat stop working. It worked on the way into town, but when she drove it home it was cold air. Any ideas as to what I should try and how I can trouble shoot it?
Old 01-29-2008, 07:41 PM
Graygeorge's Avatar
Graygeorge
Graygeorge is offline
Check to see if the blend door is broken. http://www.blenddoorfix.netfirms.com/
Also seach on this site for heater problems.
Old 01-30-2008, 10:47 AM
marragtop's Avatar
marragtop
marragtop is offline
Was the temp gauge operating normally (mid range)? If it was reading low, it could be a stuck thermostat.
Old 01-30-2008, 10:33 PM
david53ford's Avatar
david53ford
david53ford is offline
if the temp gauge read normal check both heater hoses where they go into the firewall if both hot poss blend door problem if one hot one cold poss has air lock, dirty heater core and water not passing through two type blend door problem on these unit one the electroinc accuator brakes ( gear inside strips) two the blend where the actuator mounts brakes apart good luck
Old 01-30-2008, 10:55 PM
StrokedRanchero's Avatar
StrokedRanchero
StrokedRanchero is offline
Just for the heck of it check your coolant level. Might be low, & cold enough out side for you not to overheat. JUST MY .02
Old 01-31-2008, 09:29 AM
aquanaut20's Avatar
aquanaut20
aquanaut20 is online now
Another thing to check, if the heater hoses are not hot and the engine is up to temp, check the vacuum operated bypass valve.
aero993
06-12-2016 10:43 PM
wrd0225
09-30-2014 10:53 PM
irish70
Electrical Systems/Wiring
12-08-2011 06:33 AM
GormGorm
10-22-2011 08:04 PM
rooboy
06-29-2008 12:34 AM
Quick Reply: Heater not working...
