Heater not working... - Ford Truck Enthusiasts Forums
Old 01-28-2008, 03:57 PM
AKtruck AKtruck is offline
AKtruck is starting off with a positive reputation.
My wife has a 97 ford explorer V8 awd that had the heat stop working. It worked on the way into town, but when she drove it home it was cold air. Any ideas as to what I should try and how I can trouble shoot it?
Old 01-29-2008, 07:41 PM
Graygeorge Graygeorge is offline
Graygeorge is starting off with a positive reputation.
Check to see if the blend door is broken. http://www.blenddoorfix.netfirms.com/
Also seach on this site for heater problems.
Old 01-30-2008, 10:47 AM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
Was the temp gauge operating normally (mid range)? If it was reading low, it could be a stuck thermostat.
Old 01-30-2008, 10:33 PM
david53ford david53ford is offline
david53ford is starting off with a positive reputation.
if the temp gauge read normal check both heater hoses where they go into the firewall if both hot poss blend door problem if one hot one cold poss has air lock, dirty heater core and water not passing through two type blend door problem on these unit one the electroinc accuator brakes ( gear inside strips) two the blend where the actuator mounts brakes apart good luck
Old 01-30-2008, 10:55 PM
StrokedRanchero StrokedRanchero is offline
StrokedRanchero is starting off with a positive reputation.
Just for the heck of it check your coolant level. Might be low, & cold enough out side for you not to overheat. JUST MY .02
Old 01-31-2008, 09:29 AM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
Another thing to check, if the heater hoses are not hot and the engine is up to temp, check the vacuum operated bypass valve.
Blower not working aero993 Cooling, Heating, Ventilation & A/C 0 06-12-2016 10:43 PM
front parking lights not working wrd0225 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 09-30-2014 10:53 PM
99 F350 Turn signals not working irish70 Electrical Systems/Wiring 5 12-08-2011 06:33 AM
Rear Drive lights not working, turn signals, brake lights, and hazards work GormGorm 1987 - 1996 F150 & Larger F-Series Trucks 4 10-22-2011 08:04 PM
front power windows not working rooboy Explorer, Sport Trac, Mountaineer & Aviator 3 06-29-2008 12:34 AM
Tags
1997, 2006, 97, air, blenddoorfixnetfirmscom, cold, explorer, f150, ford, heat, heater, problem, truck, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
