gauge wiring question 79 F100
hey yall, how ya been?
I have a question, I am wiring up my gauges today, I have a water temp gauge, oil pressure, and volt meter. now the question i have run into is 2 things
1) what wire can I hook the positive side of of my voltmeter so its not always just connected to the battery and i can see what its charging at??
2) what wire can I tap/splice into for the positive side of my gauge lights???
1979 F100 302 standard cab, no a/c.............
hey guys, I was under the dash with my radio pulled out and found a green 2 blade female connector, the wires that feed it are a blue with red stripe (lights) and the yellow with black stripe (keyed power) hope maybe this helps someone, maybe FORD thought it would be nice to have an accesory plug in case someone wanted to add anything to the truck
Thanx Mil1ion and everyone else who has been such a great help.
I've always heard to not even use those gaskets on the ends because they have a tendency to blow out. What I heard to do and what I did was just put a big bead of black RTV across the front and the back to take the place of the cork gaskets. It has worked great for me. Good luck. Thanks for the tip on what the radio plug looks like I'm sure mine is in there somewhere I need to dig it out because I'm getting ready to install my radio finally.
