Mig welder is that the same as a wire feed? Some of the ones on Craigslist seem pretty pricey. A guy that does some body work told me a 100 amp is good for that type of application.
I have forgotten more about welding than I remember now. Used to do a fair bit in school and college.
I have a lincoln weldpak 100 which is ok it serves its purpose as far as light duty stuff is concerned. my buddy has a little Miller which is a much nicer unit. replacing sheet metal isnt to bad. Drill out the spot welds where you can and cut where you must, fit and stitch weld back together. LMC Truck has a good selection of replacement panels in their catalogue. Haven't tried lookin for them up here although I know floors and corners are easy enough to get. You should order their catalogue if you don't already have it, it's free. Even if you don't order anything the catalogue itself sometimes comes in handy. www.LMCTRUCK.com
yes my lincoln is 110v. It works ok for stuff up to 3/16. Penetration isn't good enough on anything bigger IMO. Great for sheet metal replacement and smaller projects. If I were to do it again I would get the Miller like my buddy's it's also 110v. and is definately a much nicer unit.
I bought a Hobart yesterday.The Hobart Handler 140 Mig Welder-Output 25-140 Amp-Input 115 volts-Welds 24ga=3/16 steel-20% duty cycle@90 amps with thermal overload protection.It will be perfect for the sheet metal work.
I think I will enjoy it alot.There definately thing's I wiil be doing with it other than auto body work.It will come in handy.I got a good deal on it as well.
