How to increase fuel mileage - Page 2 - Ford Truck Enthusiasts Forums
Old 01-28-2008, 07:29 PM
zx250's Avatar
zx250 zx250 is offline
Of the next Riffraff East
zx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant future
If you can force yourself to keep you boost under 12 psi (8-10 would be better), you will see a marked improvement in your mileage. I know that it is hard to do. I have tried it and have yet to make it through a full tank before I get the lead foot. On the tanks I almost made it, I saw at least 2 mpg gain. Give it a try.
Old 01-28-2008, 08:38 PM
DR JOE DR JOE is offline
DR JOE is starting off with a positive reputation.
Quote:
Originally Posted by HighOctane
DP Tuner, better intake and exhaust, EPBV tube clean out, and make sure your fuel bowl isn't leaking with those pesky drain valve o-rings.
Why a DP tuner?? What do you mean by better intake and exhaust???
And What the h*ll is a EPBV???
Also I just changed my fuel filter and oil right after Christmas, and just check to make sure that the drain valve is NOT leaking.
I have hiway tires on the truck as it sees way more on road than off, also it is stock high, no lift here. I try not to hit the accelarator any more than I need to. I set my cruise allot.
The one thing that I would like to get a bed cover as soon a money will let me.
Thanks guys for all the suggestions, please if you have anything else... let her rip...
Also what does the small can on the back of the turbo, that has a red vac line going to it do??? And how do you know if it is working???
Doc.
Old 01-28-2008, 08:44 PM
nhill2090 nhill2090 is offline
nhill2090 has a very good reputation on FTE.nhill2090 has a very good reputation on FTE.nhill2090 has a very good reputation on FTE.
that is your wastegate actuator you are referring to with the red vac line
Old 01-28-2008, 08:46 PM
Ok thatis what I thought, I seen the red line going to a switch box and a green vac line going to the intake boot. So it get its vac from the intake boot???
Old 01-28-2008, 09:00 PM
Whit350 Whit350 is offline
Whit350 is starting off with a positive reputation.
depending on which rear end gear you have the low 20 mpg may not be attainable. My truck has a 4.10 and I am lucky to see 16 after a LONG empty run on the interstate.
You can also consider a Gear Vendors (or equivalent) under / overdrive unit. It is a unit that is installed behind your tranny (with a shortened driveshaft) and splits the gears basically to lower your RPM's at any given speed.
Old 01-28-2008, 09:07 PM
I have 3.73 gears in the truck, and the gear vendor would be nice but out of my budget at this point.
Doc.
Old 01-28-2008, 09:15 PM
Quote:
Doc.
they definately aint cheap
Old 01-28-2008, 09:16 PM
I have always wanted to know how long it would take to pay for it self in fuel savings???
Doc.
Old 01-28-2008, 10:26 PM
empiretc's Avatar
empiretc empiretc is offline
empiretc is a name known to allempiretc is a name known to allempiretc is a name known to allempiretc is a name known to allempiretc is a name known to allempiretc is a name known to all
Quote:
Originally Posted by bdrummonds
Google Dave Whitmyer (sp) and look at some of the mods he has done, he is getting about 24-26mpg, you'll see why when you find some of his pics.
You have a link? I couldn't find anything.
Old 01-28-2008, 10:43 PM
bdrummonds's Avatar
bdrummonds bdrummonds is offline
bdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud of
Quote:
Here you go David, there was a write up about him in Diesel Power. http://www.dieselpowermag.com/features/ford/0612dp_2000_ford_f350_mileage/index.html
He is a member here, but is usually found on PSN.
here is a pic of his truck
Old 01-28-2008, 10:57 PM
empiretc's Avatar
Thanks Brandon!
I just had to check it out. I got 24mpg in my truck once. No A/C, ~1950rpm, and a really good wind pushing me, lol.
Things to consider on his truck that really make it a commuter:
3.08 ring-and-pinion
235/85R16 rear tires & 225/75R16 front tires
a custom-burned chip that decreases fueling and advances injection timing under 2,000 rpm
What really made me laugh in the last paragraph:
"Dave has already managed to improve the fuel economy to 26 mpg (up from the stock 20 mpg)"
the 6637 is a dead give away, lol. i like the custom cover. i'd bet that custom chip is a DP too.
He did a great job and a 6mpg increase is awesome.
Old 01-28-2008, 11:59 PM
You said to use a DP tuner, why??? Is it better than the others on the market or is this the one that you use???
Also what HP setting are you using, or what would you suggest I use???
Doc.
  #28
Old 01-29-2008, 01:26 AM
mxratt mxratt is offline
mxratt is starting off with a positive reputation.
I have a 02' E350 7.3PS Van that I recently bought to haul my dirtbike to the races. It was an old electrician van w/ ladder racks, cage, & tool bins inside. I took the rack off, all the bins out, so I could haul 2 bikes. It has 175K on it and is totally stock and I have been getting around 18-19mpg. I was considering a chip, exhaust, intake, to gain some power but I don't want to lose any mileage. I think w/ the chips it's hard to gain mileage when your adding more fuel to the motor.
What kind of mileage did you get before the mods?
  #29
Old 01-29-2008, 09:22 AM
sflem849's Avatar
sflem849 sflem849 is offline
sflem849 has a good reputation on FTE.sflem849 has a good reputation on FTE.
I wish I could post my excel spreadsheet of my mileage over the last 2.5 years. Yes, I am a loser, but it really can show you some things. You can see the downturn w ULSD, Winter Blend, New DP Tuner (That is not the tuners fault. Black Smoke!!! ) It averaged 15.7 in the end w 10.99 the lowest pulling gn and 21 on 55 mph roads.
Nobody has mentioned intanks or 203* stat??? Wouldn't eliminating air in the system be more efficent? Isn't running the engine warmer better for efficent combustion?
I am struggling with my physics. Why are little tires better? Wouldn't slightly larger tires push the truck farther for one turn of the motor?
  #30
Old 01-29-2008, 09:36 AM
empiretc's Avatar
Quote:
the intanks are definitely worth doing, but I didn't notice any mpg gains.
the 203 thermostat has been debated quite a bit. Gene posted a pretty detailed thread about the pros and cons. It just really depends on where you live. Its pretty hot where I live and I don't think I would really benefit from the 203.
1983 Ford Ranger Diesel bad fuel mileage rkim777 Ranger & B-Series 9 10-06-2015 10:33 PM
Increasing mileage Ford_Fan1 6.0L Power Stroke Diesel 32 07-02-2015 12:08 AM
2004 5.4,3V Crew Cab,gas mileage mchemical 2004 - 2008 F150 11 09-05-2014 10:49 PM
Gear Vendors Overdrive Units cfpinz 1994.5 - 1997 7.3L Power Stroke Diesel 0 03-19-2014 08:31 PM
1996 Ranger 2.3L Automatic, horrible gas mileage? Kijutsu Ranger & B-Series 3 11-09-2007 10:09 AM
Tags
2004, 73l, bull, bulldog, chip, chips, dog, dp, f250, ford, fuel, increase, mileage, mpg, timing, truck, tuner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
