Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Expedition & Navigator 1997 - 2002 and 2003 - 2006 models
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-28-2008, 01:34 PM
polcat's Avatar
polcat is starting off with a positive reputation.
Starting Issues
I just got this Expedition about two weeks ago, and already running in to a small issue. I takes3-6 times for the engine to turn over to start after I intially start in the morning. Though about fuel fitler so I changed it. No problems their did cure probelm. Would still take several times to start. Now if I shut it off let it set for 30 sec. it starts fine. But after about 15+ mins or so, it would take several cranks to get it started. regardless were I had the throttle at. I can hear the fuel pump comming one. Did not have a pressure gauge, but turned key on and pressed on the shrader valve and lots fuel came out. So decide to tape on tape on the fuel pressure valve ont he fuel rail were the vaccum line is hooked up. NO help, but did remove the vaccume line coming off the intake and blew back through it. Hooked it back up engine started good??.. So let it set for 15-20 min. Seemed to start fine. Tried again. let set 15-20 min. Started good. Any you guys run into this issue. wander if their is a vacuum issue. possible canister clogged? not letting enough vaccum to open the fuel vavle on the fuel rail?
__________________
1966 F100 Styleside
418Fe One Bad FE!!!
12.66@100.98
http://www.putfile.com/bpohlmeyer
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-28-2008, 06:50 PM
madsonp is starting off with a positive reputation.
What year is your expedition ? Not that I can help but I thought it might help narrow it down.
  #3 (permalink)
Old 01-29-2008, 12:24 PM
polcat's Avatar
its a 2000 expy..i with 114,000 miles. Did notice yesterday that if you try starting to quick it will take along time to start. But i also removed the vaccum canister and blew it out.. So far it is starting good?
__________________
1966 F100 Styleside
418Fe One Bad FE!!!
12.66@100.98
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
