Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-28-2008, 11:44 AM
E30tdf is starting off with a positive reputation.
Help - Oil Pump Drive - Out of Position
I have reassembled a rebuilt 302 and during the course of trying to verify the oil pump is generating pressure I have apparently lifted the drive rod up out of the pump and now I ca't get the drive tool or distributer on.
Is it remove the pan time or is there a way to reach it from above with a tool or such?
Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-28-2008, 02:20 PM
My machinist has answerd my quest. Thanks
  #3 (permalink)
Old 01-28-2008, 06:45 PM
mark a. is gaining momentum as a positive member of FTE.mark a. is gaining momentum as a positive member of FTE.
You should always adjust the collar on the drive shaft when you are putting in the oil pump, but now you know that.
__________________
'79 F250 13" lift 42" Super Swampers
  #4 (permalink)
Old 01-28-2008, 09:35 PM
The best teacher is experience! Yep, I screwed up! Now I know how it is to be done. These little details are not well covered in Chilton or Haynes....:-)
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
