Won't shift into 4th gear?
A 4 speed auto behind a 460 in 1988? What trans would that be? Too early for the E4OD, right? And a stock AOD won't take a 460's torque. Wouldn't it instead have the C6 3 speed? Maybe I missed something, maybe its been swapped out. But a E4OD needs a computer to shift it.
[updated:LAST EDITED ON 13-Nov-01 AT 11:55 PM (EST)]It may sound silly,but check it's fluid level,and it's condition.I'd take it to a tranny shop if the fluid level is fine,and it is it's normal color.Just have them check it over.If your truck was used for heavy towing&snowplowing(I think you said it had a snowplow on it),it could need work.If it has a lot of miles on it,it could be time for a rebuild.Have a shop take it on a quick testdrive.They'll be able to tell you the problem.It could be a simple fix,or it could be a problem.(The AOD was basically put behind 302s.Never behind a 460.The E4OD came out in 1990.)Hope everything works out for you.Good luck.
The E4OD is from "late" 1989. The first full model year of availability was 1990. I pulled an E4OD out of a 1989 model year donor with an August 1989 build date. Another month and the truck would have been a 1990.
If the original poster confused the specs of his truck, and it does indeed have the E4OD, then a possible explanation is the 4th gear lockout switch. Maybe it got bumped and is telling the computer not to use 4th.
Ludis
Ludis
kirkharrod
15
05-03-2017 10:51 AM
Irishpdx
06-09-2004 09:15 AM
