up-pipe leaking
up-pipe leaking
Found my right up-pipe was leaking. I have been searching the posts and see they make an update for the up-pipes. They are around $300? I am kinda on a budget so I don't think that is an option. If I were to replace just the donuts, is there any other place to get them than just from ford. Does the turbo have to come off to replace the donuts?
here is a pot I read a while back
Dont use the ford donuts, Fel Pro P/N 8194 seals it far better, Dunno what they make em out of but they squish far better than the rock hard donuts, Just lube em up with high heat anti seize so they squeeze into every nook n cranny that needs it, It works Very Well!
I would imagine your local parts house has them. They should be able to cross reference that part # or their own in house part # associated with it.
Just googled it and that part is a small block chevy donut. Got lots of hits from psd owners using them.
Studawg
09-27-2011 02:06 PM
quality1construction
10-05-2009 06:39 PM
