Popping noise from inside the doors?
Yes, loosen the hex screws on the latch- you don't need to remove them. Then tap the latchwith something that won't mar it- I used a hammer against a piece of wood. The Latch will move- but it takes more force than you would guess. Once moved, tighten the latch up again. I had to do this on my first Superduty as the door did not align with the body of the truck and when I tured sharply to the right, the door ajar light would come on. Once I moved the latch a little, things worked properly.
