electric door locks - Ford Truck Enthusiasts Forums
electric door locks
Old 01-28-2008, 01:55 AM
keith56_cruz_cab's Avatar
keith56_cruz_cab keith56_cruz_cab is offline
keith56_cruz_cab has a good reputation on FTE.keith56_cruz_cab has a good reputation on FTE.keith56_cruz_cab has a good reputation on FTE.
electric door locks
Has anyone here installed electric door locks on a 56? You know like the ones on new cars where you push your keyfob and the doors lock an un-lock.
I still want to use the stock handles on the outside.
Im open to change the handles on the inside, the stock ones I could live without.
Old 01-28-2008, 09:03 AM
LEckart's Avatar
LEckart LEckart is offline
LEckart is starting off with a positive reputation.
Rocky Hinge Co. makes a locking bear claw latch that might work for what you're doing. I think it can be setup for remote control. www.rockyhing.com I'm along way from worrying about that at this point. Please let us know what you decide and how the install goes.
Old 01-28-2008, 09:14 AM
jniolon's Avatar
jniolon jniolon is offline
jniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud of
kEITH,
One of the folks that advertise in CT or CCT... Autoloc, maybe... advertise a remote entry kit.. up to about 4 functions. check the advertisers in the magazines.. I know a kit is available. At least for open/close function. Since you're using the orig handles outside it might be a task to get the lock/unlock function. Come on Keith !!! shave them handles off
later
john
Old 01-28-2008, 12:19 PM
B/B ford's Avatar
B/B ford B/B ford is offline
Clean & Classy
B/B ford has a good reputation on FTE.B/B ford has a good reputation on FTE.
Keith, talk to AXracer, He has a great set up on his that I am going to install one of these days.
Old 01-28-2008, 06:36 PM
edsf100's Avatar
edsf100 edsf100 is offline
edsf100 has a very good reputation on FTE.edsf100 has a very good reputation on FTE.edsf100 has a very good reputation on FTE.edsf100 has a very good reputation on FTE.
Hi Keith, Also my next project and was looking at the kit from LMC.
http://www.lmctruck.com/icatalog/fa/0014.asp
Old 01-29-2008, 12:50 AM
Hey thanks guys, ed I ordered the one from lmc I'll let you know how it works out.
Old 01-29-2008, 07:22 PM
rhopper's Avatar
rhopper rhopper is offline
rhopper has a good reputation on FTE.rhopper has a good reputation on FTE.
I was at a big hot rod supplier last summer while out of town on vacation. I asked the sales guy about bear claw latches and locks, etc as they sold the autoloc brand. The sales guy, very softly told me to go to rocky hinge for the latches as the autoloc wasn't as well made and they've had trouble with them. FWIW.
Old 01-29-2008, 11:15 PM
fatfenders56's Avatar
fatfenders56 fatfenders56 is offline
fatfenders56 has a good reputation on FTE.fatfenders56 has a good reputation on FTE.fatfenders56 has a good reputation on FTE.
ditto, I have used both and the Rocky hinge kit is #1, I used them in my own truck, can't say more than that!
Old 01-30-2008, 07:39 AM
Last Chance 55 Last Chance 55 is offline
Last Chance 55 is starting off with a positive reputation.
My Fibercab came with power door locks and actuators. At first, I didn't think that I would like them, but after getting the truck going I am glad I did. I am using a 7 function remote for the doors and windows. I still have extra functions for the butt massage machine and a trunk lid. I need to call Bebop's though and get the brand of the locks and actuators for future maintenance purposes though. Good luck on your install.
Old 02-04-2008, 01:26 AM
Got the kit from lmc not sure I want to use it!
made in taiwan all plastic actuators?
Old 02-04-2008, 10:42 AM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Keith look in my "making changes" gallery for pix of how I modified my stock latches to use the remote lock actuators. I am still able to use the stock handles and key locks.
All the actuators are filled nylon AFAIK, but my mod does not require much effort to lock/unlock, just the effort needed to turn the key. Only need strong actuators if you are actually opening the door latches like with shaved handles, not to operate the lock mechanism. I tossed the switches and used better ones. I once bought a grab bag box of auto electrical part packages that contained several sets of OEM switch replacements if you need some.
Old 02-05-2008, 12:22 AM
thanks ax
thats what I want to do use stock outside handles and have electric locks.
Except Im using bear claws from mid fifty. I like your inside miata handles,
you noted in your that gallery you were going to trim the outer lip do you have to?
I like the way it looks and since I want to use door panels Im thinking It would hide the cut-out ? Am I correct?.... also what type of power window kit is that? Do you like it?
Old 01-09-2009, 11:15 PM
paul_scooter's Avatar
paul_scooter paul_scooter is offline
paul_scooter is starting off with a positive reputation.
I know this is a old topic but its new to me. Has anyone put the LMC remote control door locks on a F-1? Below is the link, its at the bottom left of page 14. I was thinking this might be a easy way to have the door lock on the drivers side.
LMC Truck Parts - Page 14
Old 01-11-2009, 10:26 PM
f1barry f1barry is offline
f1barry is starting off with a positive reputation.
I ordered the LMC remote locks for my F1 and couldn't figure any way to use them. LMC was no help other than taking them back. If anyone has a way to install them, I would like to put them in.
Trying to figure out the lock mechanism on my new altmans.... clintonvillian 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 10-24-2014 12:05 AM
Door Locks , Locked up, Any help? Curt Bates 1987 - 1996 F150 & Larger F-Series Trucks 5 07-10-2013 08:06 AM
Inside Door Handles from the Darkside CharlieLed 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 03-02-2011 10:01 AM
Rear Hatch Not Locking.......Did Not Know DSMMH Excursion - King of SUVs 12 03-08-2010 12:01 PM
Door locks 99 SD oldscout 1999 to 2016 Super Duty 0 11-24-2003 05:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
