Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-27-2008, 10:41 PM
Black450 is starting off with a positive reputation.
CDL Question
If I pull a 10 ton flatbed gooseneck with my 450 am I required to have a CDL?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-27-2008, 10:52 PM
mnmwhit is starting off with a positive reputation.
Not I you are doing it for your self and not making money with it. The minute you use it for profit or "for hire" you need a CDL.
In most states you will need to go through the weigh stations and the sign will say all truck with a GCVWR of 10,000 and above enter. And you will be subject to inspections.
__________________
Max W
06 F-350 4X4 6.0 PSD NORTH POLE, ALASKA
Mobil-1 5-40 turbo diesel truck oil from day #1
98 gallon transfer flow tank
Leer topper insulated
MBRP SS409 turbo back Off-Road duel exhaust-CAT IS GONE
AstroStart 2-way Auto start
Go Rhino pushbar/brushguard,4-9" Lite-Force moose lites
  #3 (permalink)
Old 01-28-2008, 02:40 PM
rbaker6336's Avatar
rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.
if your GVW is above 26000 lbs yes
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install
DooDad???=(dfuser ram air)
'98 Grand Cherokee
'86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
  #4 (permalink)
Old 01-28-2008, 03:07 PM
SANDDEMON08's Avatar
FORD POWERSTROKE JUNKY
SANDDEMON08 has a good reputation on FTE.SANDDEMON08 has a good reputation on FTE.
Quote:
I thought there was also a clause if your are towing over 10,000 LBS a CDL is also required,unless your not for hire, in that event your still need a special endorsement here in Nevada to tow over 10,000 LBS.
__________________
Got beer ? 498HP 965
2008 F350 SD CC FX4 ON 20's, 6.4 PSD,TORQ-SHIFT,3.73 REARS, NAV, BLACK LEATHER SEATS,DASH DAQ GAUGES, AFE STAGE II INTAKE,SPEARCO INTERCOOLER,CUSTOM TUNING, SEIC MOD,AMP REASEARCH STEPS, LINE-X SPRAY IN BED LINER, T-REX BILLET SIDE VENTS.
  #5 (permalink)
Old 01-28-2008, 03:15 PM
rbaker6336's Avatar
in florida the only thing exempt from the 26000 rule is RVs and that should be included
__________________
Ray
'98 Grand Cherokee
PAA #35
  #6 (permalink)
NJF350SD's Avatar
NJF350SD is gaining momentum as a positive member of FTE.NJF350SD is gaining momentum as a positive member of FTE.
This is correct. There is, however, an Air Brake clause. A CDL is required (Class B minimum) on anything with Air Brakes regardless of GVW.
-Chris
  #7 (permalink)
Old 01-28-2008, 03:44 PM
rbaker6336's Avatar
Quote:
-Chris
guess I forgot that,but been close to 20 years since I got CDL
florida no longer lists air brake endorsement on class A CDL
__________________
Ray
'98 Grand Cherokee
PAA #35
  #8 (permalink)
Old 01-28-2008, 04:54 PM
So if I'm hauling trees or anything like that over the interstate for my business, I'm required to have a CDL? What if I'm just hauling local, do I still new one?How difficult is it to get a Class A or B CDL? Sorry for all the questions. Thanks, Sam.
  #9 (permalink)
Old 01-28-2008, 05:54 PM
tex25025's Avatar
tex25025 is gaining momentum as a positive member of FTE.tex25025 is gaining momentum as a positive member of FTE.
If your hauling to and from different states then I would heavily advise getting it A. you might be going into a state that requires it even if your state doesn't and B. it's for your business. If your hauling local you need to check your local laws at the DMV or DOT, I would imagine even the state government website would have it. Here you just have to do knowledge tests, although they highly suggest truck driving school(this was mainly focused on big rigs I think, but they lowered some of the weight limits so more and more of the light trucks have to take the exams for those that do this for a business). Here we have an exemption for farmers and nurserymen if it is within a 150 mile radius, otherwise you have to get it. There are a few other exemptions, but I think that would be the one that you might want to take a look at to see if your state has it as well.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
SCT w/Spartan tunes(including FICM tuning)
Fuel Regulated Return
FASS 150/180
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #10 (permalink)
Old 01-28-2008, 06:38 PM
mudmaker's Avatar
mudmaker has a good reputation on FTE.mudmaker has a good reputation on FTE.
I would get one just to be safe. Technically a picky DOT officer could make you park the trailer not having a CDL due to the fact that w/ it hook up you are over 26k. I am assuming you can take the test w/ your 450. Here in MT you can take it with any vehicle combination that exceeds 26k. I took mine in my SRW F350 pulling a tandem axle dually 30' gooseneck. The only thing you wont have is a air brake endorsement, but if you want or need that you just have to get a vehicle w/ air brakes to take an additional test. No trailer needed for that one.
If DOT officers want to they could stop every 20k gvw trailer behind a pickup and make sure they have a cdl, but the truth is they dont bother private vehicles much. It would be a little hard to call a flatbed an RV.
__________________
Marc
2002 F350 SRW CC LB 4X4
2002 Excursion Limited 4X4
PAA #20
  #11 (permalink)
Old 01-28-2008, 06:46 PM
randomhero1172 is gaining momentum as a positive member of FTE.randomhero1172 is gaining momentum as a positive member of FTE.
I know its different state to state - but whats the extent of the test? In michigan you get a chauffers (10,000 - 25,999) in the middle. talking to some cops they said its just a fundraiser and all you have to do is take the EASIEST test.
__________________
- Joe
2002 f-250 CC long bed 7.3 PSD - 295,000mi: 6637, Zoodad, Foil Delete,Silverstar Ultras, CCV, 5" MKO Strait Pipe, Cab Lights, WW.
NEW!!!! - 1990 f-350 dually 7.3 IDI 12ft Alum. Boc. 197,000. A little shaky
  #12 (permalink)
Old 01-28-2008, 06:58 PM
mudmaker's Avatar
In MT you just take a written for what ever license you want. In my case I took commercial, combination, double/triples, and air brakes. The test is easy as they have study guides available to prep for the test. Once the writtens have been past then you make an appointment for the driving test. Show up with the vehicle, make sure you have your proof of insurance. Take the test, pre trip is the easiest part to mess up on. I think my driving test lasted less than 30 minutes total IIRC. I had to schedule a second driving test for the air brake part. Some guys put a small trailer behind a dumptruck for the combo and airbrake, but trying to back up my dumptruck w/ a little trailer is a royal PITA, so I went the other way and just took 2 driving test.
__________________
Marc
PAA #20
  #13 (permalink)
Old 01-28-2008, 07:48 PM
I have a CDL and I am in Law Enforcement. Once you get a CDL it will be like admitting you are for hire. The the DOT man will want to see your health and physical card and long form certificate. Then are you going to register you truck commercialy? Get a base plate? How many states will you register your base plate in? Commercial insurance with a $1,000,000 minimum liability policy? Don't forget advalorum tax? I probably spelled that wrong. Fuel taxes have to be paided for each mile you run in each state to the state. You will need ICC numbers on the side of your truck
You did not say what you were hauling and why or what state you were in. That would make a difference. Mosts state have a "farm" or "not for hire" provision. I would just keep pulling the trailer. If you get pulled over most cops around here would just write you a "fix it" ticket.
__________________
Max W
  #14 (permalink)
Old 01-28-2008, 07:58 PM
UGA33's Avatar
Yeah Come On!
UGA33 is gaining momentum as a positive member of FTE.
Do not underestimate the pretrip!! I had a woman give me mine and she LITERALLY had no idea what she was doing. I pointed at the coolant overflow bottle with RED coolant in it and she said i showed her the windshield washer fluid!! How did she get a job?
__________________
2006 F-250 Lariat Crew Cab Shortbed FX4
-Josh-
*6.0L PSD*MBRP Turbo-back*35" BFG Mud Terr. KM2's*Leveling Kit w/ Daystar Coil Spacers & Rancho RS5000's*Spartanized SCT X3*Autometer EGT & Tranny guages*Coolant Filter*CCV Reroute*F-350 blocks*High Idle Mod
  #15 (permalink)
Old 01-28-2008, 08:14 PM
rbaker6336's Avatar
not really true,I have a CDL and only means I can drive almost any commercial vehicle leagally
my truck is registered commercial only brcause of its weight
I am not required to have a health certificate or drug test because I don't haul commercially
if you are hauling commercially most states only require $300k liability unless you are hauling interstate
florida has no advalorum tax only road use tax and all truck 26000 gvw and over have to post DOT numbers that are free
I don't think florida has any farm or not for hire provisions
if you are stopped if you are stopped without proper license you will most likly be ticketed
__________________
Ray
'98 Grand Cherokee
PAA #35
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
