Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 01-28-2008, 09:19 PM
mudmaker's Avatar
mudmaker has a good reputation on FTE.mudmaker has a good reputation on FTE.
Quote:
Originally Posted by mnmwhit
Once you get a CDL it will be like admitting you are for hire. The the DOT man will want to see your health and physical card and long form certificate. Then are you going to register you truck commercialy?
Are you saying if you have a CDL that automatically make any vehicle you drive commercial? The DOT laws are very specific as to who needs ICC Authorities, if you are hauling "FOR HIRE" across state lines. Once that happens all the base plate, fuel reporting, etc applies.
The cops in your area might not care, Try a Federal DOT officer. Some are easy going, but most of the ones I have dealt with are not. If you have a CDL at least you are legal to drive the vehicle you are driving. The key is "not for hire" as long as your not hauling for hire you dont need anything more than your normal registration. If you are out of state and they decide you need a trip permit that is easily fixed at the scale or port of entry.
__________________
Marc
2002 F350 SRW CC LB 4X4
2002 Excursion Limited 4X4
PAA #20
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 01-29-2008, 01:59 PM
tex25025's Avatar
tex25025 is gaining momentum as a positive member of FTE.tex25025 is gaining momentum as a positive member of FTE.
I have a CDL and I am in Law Enforcement. Once you get a CDL it will be like admitting you are for hire.
That depends on what type of class of CDL you get or if the state that you are hauling in has a temporary permit for you to carry that load that expires within a certain time period. There are alot of ways to get the necessary documents without the extreme consequence that you are hinting at. It veries between state to state though what exemptions or qualifications that you need to have. There is no blanket answer. However, the base requirement is usually 26,001 lbs or over(it makes no mention of for hire or just hauling for recreational use) and if your hauling for over a specific distance(which I do for horse shows all the time), it by no means means that you are for hire, you could be doing this for your own hobby or what not. You have to do other applications to qualify for "for hire" status, atleast in the two states that I have lived in and in the states that I travel in consistantly.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
SCT w/Spartan tunes(including FICM tuning)
Fuel Regulated Return
FASS 150/180
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #18 (permalink)
Old 01-29-2008, 06:30 PM
mnmwhit is starting off with a positive reputation.
That is the point exactly. We can not speak to his issue. We do not know where he is, where he goes, what he hauls. It will make a big difference state to state. My truck and fifth wheel travel trailer weighs more than 26,000 loaded.
Quote:
__________________
Max W
06 F-350 4X4 6.0 PSD NORTH POLE, ALASKA
Mobil-1 5-40 turbo diesel truck oil from day #1
98 gallon transfer flow tank
Leer topper insulated
MBRP SS409 turbo back Off-Road duel exhaust-CAT IS GONE
AstroStart 2-way Auto start
Go Rhino pushbar/brushguard,4-9" Lite-Force moose lites
  #19 (permalink)
Old 01-29-2008, 07:06 PM
tex25025's Avatar
I would say that he hauls trees as that was the example that he gave, and hauling trees isn't something that the average joe lists as an example for hauling, but I could be wrong. Also I would say that he is in Florida(but that is assuming that the information is accurate on his profile). Based on that, it looks like he has the same ag. exemption that I mentioned in one of my earlier posts about 150 mile radius. A couple of other exemptions as well, one more then they have here actually, but it won't apply to him as he is hauling for his business.
__________________
Fluidampner
Headstuds
FASS 150/180
  #20 (permalink)
Old 01-29-2008, 07:07 PM
mudmaker's Avatar
The OP ask if he needed a cdl. It just comes down to how a DOT officer views his use. As easy as a CDL is to get he might as well have one.
__________________
Marc
PAA #20
  #21 (permalink)
Old 01-29-2008, 07:12 PM
tex25025's Avatar
Quote:
I wouldn't go by that at all. You might be talking to someone that is really lax about what he hauls, but then you might be pulled over by a person that is gungho about upholding the law. For instances, here you don't have to have tags on your trailers unless you go out of state(even then states are supposed to observe other state laws when it comes to DOT regulations) however, I cover my butt in that regard just keep from giving them one more reason to pull me over. I would vote to get a CDL as well, they are fairly easy(which is kinda scary because alot of people don't have any business hauling those types of loads) and it just covers your butt.
__________________
Fluidampner
Headstuds
FASS 150/180
  #22 (permalink)
Old 01-29-2008, 10:20 PM
Your vote matters!!!
I didn't know we were holding an election
I vote for Oliver North
__________________
Max W
  #23 (permalink)
Old 01-29-2008, 10:31 PM
tex25025's Avatar
Ok, lets see if I have the count correct, that is 3 false statements that you have said about me in the last 2 weeks, and now we have an ad hominem fallacy to your tally(to let you know that isn't a good thing). Your on a role man. I do want to add that given that fact that you had accused me of being childish, you are the only one that has actually attacked my character, the only thing that I have done is countered your points with my own(which is the logical thing to do), so you might want to reconsider who is being childish here. If you find issues with what I have said please mention them, attacking my character is irrelevant, fallacious and childish.
__________________
Fluidampner
Headstuds
FASS 150/180
  #24 (permalink)
Old 01-29-2008, 10:51 PM
Black450 is starting off with a positive reputation.
Thanks for all the replys guys. Just to clarify, I am a landscape and irrigation contractor in north Florida and sometimes travel to south florida to pick up large palms. So far I've just been using my 10,000# trailer so I know I'm not over 26,000#, but I'd eventually like to get a 10 ton gooseneck so I can haul more at a time and also haul my Bobcat along with some trees for local installations, then I'd be over 26,000#, thats why I asked about the CDL. Sorry for another question, but who is required to stop at the weight stations? I've never stopped with my 10,000# trailer loaded down with palms and have never had a problem. Thanks again for all the replys.
  #25 (permalink)
Old 01-29-2008, 11:03 PM
rbaker6336's Avatar
rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.
Quote:
that seems to be a gray area in florida
on state and US roads all trucks and trailers,even pickups
on interstate all loaded commercial registered trucks
I have also never stopped on interstate scales even with my backhoe behind,but have talked to people who have been stopped for not going through scales
guess it boils down to the officer watching
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install
DooDad???=(dfuser ram air)
'98 Grand Cherokee
'86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
  #26 (permalink)
Old 01-30-2008, 12:30 PM
magusjinx is starting off with a positive reputation.
I would vote for getting a CDL being as how you are using the equipment in a commercial venture ... If you were just hauling your private 5th wheel or trailer and not doing any business of a commercial nature then I would say "maybe not" ...
You might be considered "for hire" because you have a business that utilizes the particular vehicles and equipment that "might" be regulated by DOT ...
__________________
Current:
1986 Ford F250 XL Exploder-4x4-6.9 IDI-C6
.. body by Rusty Crunchy
1986 Jeep Cherokee Pioneer Limited-2.8L P.O.S.
Past:
1965 Chevy "Assembled" 1/2 ton
1964 Chevy 3/4 ton
1964 GMC 1/2 ton
1967 Buick Special, 310 Wildcat, 2-speed slushbox
1967 Fairlane GT 500, 428 Cobra, twin turbo, NOX
  #27 (permalink)
Old 01-31-2008, 10:10 AM
Yep sounds like a election campaign to me. My you are sensitive for a guy that likes to argue about everything.
__________________
Max W
  #28 (permalink)
Old 01-31-2008, 10:23 AM
slowmans is starting off with a positive reputation.
anything over 10,000 pounds requires a medical card, anything over 26,000 pounds requires a class b cdl, you may be required to get a class c cdl in your case?I would just call the dmv or stop in at the weigh station (unloaded of course ) and ask those guys will help you out!
(this is for comercial purposes )
__________________
2006 F350 LARIAT 6.0 SUPERCAB 4X4 FX4
4"MBRP T-409 TURBO BACK COOL DUALS
EDELBROCK PERFORMER IAS SHOCKS
ACCUFAB POLISHED INTAKE ELBOW
KITTY IS AT THE VET!!!
305/65/18 BFG ALL-TERRAINS
DRINKING B-5 REGULARLY
08' REAR DIFF. COVER
  #29 (permalink)
Old 01-31-2008, 12:45 PM
tex25025's Avatar
When people get things wrong about me(and that are irrelevant to the conversation in the first place) I do get sensitive. You want to debate logically, I'm all for that, however you are not(rather or not you know that is your problem).
__________________
Fluidampner
Headstuds
FASS 150/180
  #30 (permalink)
Old 01-31-2008, 12:46 PM
tex25025's Avatar
Quote:
Class A CDL
__________________
Fluidampner
Headstuds
FASS 150/180
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
