Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Expedition & Navigator 1997 - 2002 and 2003 - 2006 models
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-27-2008, 07:39 PM
D Ray is starting off with a positive reputation.
IAC valve?
Similar questions are mentioned on here quite a bit but here's another one with slightly different things happening....
97 expy, 4.6
I am having starting issues when it's cold outside. When I turn on the key I don't here the priming sound under the hood but I hear a single "click". Sometimes it will just die out after firing and sometimes it idles at a low rpm. Sometimes I have to hold it at about 2500 rpms for a few seconds to keep her going and then it runs fine. Sometimes it will click after firing (like something has freed up and then it will run.
Is this the IAC valve or could it be fuel pump issues?
Thanks,
D Ray
__________________
D Ray
91 F150 4x4 (pics in gallery) 5.0L
97 Expedition XLT 4x4, 4.6L
05 Escape XLT 4x4, 3.0L
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-28-2008, 11:09 AM
buzzard's Avatar
buzzard is starting off with a positive reputation.
Hard to tell from your description, but when my IAC valve went my truck would crank fine but just not start and/or idle when cold. It would stay running if I kept the rpm's up like you mention.
__________________
Jim
1968 F250 CS, 390
Pebble Beige/Wimbledon White
2000 4x4 Expedition, 5.4L
White
  #3 (permalink)
Old 01-28-2008, 11:53 AM
projectSHO89 has a good reputation on FTE.projectSHO89 has a good reputation on FTE.
The "priming" sounds should be coming from the fuel tank (that's where the pump is at), not under the hood.
Crack the throttle 1/4 way and see if that helps. If so, the IAC is sticky and should be cleaned (sometimes helps) or replaced.
If not, cycle the key several times by turning to RUN for 3 seconds, then OFF. Then, hit the starter. If it fires right up, you've got a sluggish fuel pressure buildup that might be due to a restricted fuel filter or line or from a weak pump.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
