Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Computer Chips and Tuners
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-27-2008, 02:54 PM
93rangergoingfast is starting off with a positive reputation.
computer swap
Is it possible or has anyone ever swaped a mustang computer in there 4.6 F-150 if so how did it work and did you have to change anything out.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-28-2008, 05:04 PM
ReAX's Avatar
Molon Labe
ReAX is gaining momentum as a positive member of FTE.ReAX is gaining momentum as a positive member of FTE.
4.6 to 4.6 should run decent, but the pinout is most likely different and you may have extra features on the mustang that your truck doesn't use. Such as electric fans, traction control, ect.
If your looking for power or tune-ability, you should be able to tweak a 96+ f150 easily.
__________________
Too many mods to list, so click here.
-MECP 06/27/08
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
there's a very fine line between not listening, and not caring. I like to think that I walk that line every day of my life.
  #3 (permalink)
Old 01-28-2008, 06:54 PM
I did the P.I. swap Heads,Cams,Mustang Intake,Professional Products Upper Intake Plenum, And 75mm Throttle Body It does not perform like it should and it misses every now and then so I thought maybe I would need a different tune there is no dyno around town so I cant get a tune that way any suggestions.
  #4 (permalink)
Old 01-28-2008, 08:24 PM
ReAX's Avatar
Molon Labe
a/f should be the same regardless of airflow, which the MAF will read. Sniper's special forces will allow you tweak your a/f ratio to your hearts delight. SCT can mail you a custom tune. I really like my Special Forces. For performance, double check your vacuum lines, clean the MAF, change your o2s and fuel filter. The 20-30 hp you picked up shouldn't feel like much in a 5000lb truck unlike a thousand pound lighter car.
__________________
-MECP 06/27/08
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
