How much does retarding the timing by 1 degree affect the motor in power?
I have an 07 4.6L with no mods other than a dumped Flowmaster, and now, an Edge tuner.
I like to use 87 octane gas and the quality of gas around where I live is real bad for some reason. My truck lightly pings at tip-in at low RPMs under load but if I run colder plugs and retard the timing by 1 degree with my Edge tuner the pinging goes away.
I'm just curious how much power I'm giving up. I run the Level 2 tune.
How far can you retard the timing? Is there a limit before something weird happens?
With just the plug change (2 ranges colder) most of the pinging goes away. The -1 timing takes the rest away.
My mileage hasn't changed and I can't feel any lost power.
My wife's 05 Escape will run on anything.
