Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-26-2008, 07:23 PM
Barnfresh41 Barnfresh41 is offline
Garage is empty, add now
Barnfresh41 is starting off with a positive reputation.
Manifold and Fuel Pump Problem
Hello. As you may recall in my last posting I was trying to figure out the best way of fitting a 302 into my 41 pickup, however things of changed. We have now decided to drop a 59ab in it and we are having a little trouble with the fuel pump hitting the manifold. We have an 8ba offenhauser 4 barrel manifold and a stock 59ab fuel pump stand with both an 8ba and 59ab fuel pump. Are problem is that the fuel pump is hitting the manifold which does not allow you to bolt it together properly. The 8ba stand as you probably know is offset, and I am wandering if it is okay to use the 8ba stand with the front draft tube on the 59ab. If we decide to do this we would not be able to use the breather cap. We are planning to use a mechanical fuel pump with a back up electrical pump. If you guys have any suggestions please post.
Thanks,
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
