Is it possible to DIY the front shocks? - Ford Truck Enthusiasts Forums
Old 01-26-2008, 08:30 AM
RussWhite RussWhite is offline
RussWhite is starting off with a positive reputation.
Question Is it possible to DIY the front shocks?
Has anyone on the forum changed the front shocks on an '05 or similar 4WD SCREW? If so, I sure would appreciate your comments on what to do and any special tools required or things to be careful about. I have the shocks and the time. Thanks, Russ
Old 01-26-2008, 09:08 AM
MBBFord's Avatar
MBBFord MBBFord is offline
MBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to behold
It is a pretty simple process, and shouldn't take more than about 2 hours to do all of them.
You will need a spring compressor. I rented one from autozone, and got all the deposit back when I returned it. You will need the one that compresses the spring from the outside not the inside(the shock is inside).
IF you can install the Leveling kits on these trucks, then this is even easier.
I just seperated the upper ball joint from the knuckle, swung it out of the way and zip tied it up so the axle shaft wouldn't drop all the way and possibly ruin it.
Only thing to make sure of is the possition of the spring, mark the front of the spring before you take it out, then put the marked part back faceing up front.
Take the whole coil over shock out and then compress the spring, swap shocks, and put it back together.
Only thing is you will need different size metric wrenches and deep sockets.
Old 01-26-2008, 09:46 AM
coin1230 coin1230 is offline
coin1230 is starting off with a positive reputation.
I am thinking of doing this and like to know the size of the deep sockets.
Old 01-26-2008, 09:53 AM
MBBFord's Avatar
I really don't remember what the sizes were....16, 17 19, something like that.
I bought a set from harbor freight for about $10, which would be about the price of 2-3 single sockets.
You will need different size combinations for the rear..... they're easy to change if you have the proper sizes.
Old 01-26-2008, 11:07 AM
GlennJ GlennJ is offline
GlennJ is starting off with a positive reputation.
Coin1230, I see you are from SoDak. MBBFord is from Lousiana. If they use salt on your roads in Winter the job is going to be tougher than in LA. More muscle and longer socket handles.
Old 01-26-2008, 11:38 AM
MBBFord's Avatar
Nothing some WD40 and a cheater bar won't fix.
Old 02-01-2008, 11:30 AM
great white great white is offline
great white is starting off with a positive reputation.
RuusWhite, did you get a chance to replace your shocks? If so how did it go?
Old 02-01-2008, 12:52 PM
Well, I am part way done. I installed the rears as they were easy. Now it seems there is a little noise from back there when I go over a bump. The ones I removed had no resistance to movement at all. So I am glad I replaced them. I have a spring compressor on order from Harbor Freight and will attempt the fronts when it gets here. I'll try to remember to update this thread with how that goes and maybe even some pictures if I don't screw it up. Russ
Old 02-03-2008, 02:04 PM
baitmaster baitmaster is offline
baitmaster is starting off with a positive reputation.
A few mo back I replaced the rears on 05 XLT. Was amazed at how easily they pushed down, considering they only had 5K m on them. Havent tackled the fronts yet, but after seeing how bad the rears were, it wont be long.
Old 02-03-2008, 04:00 PM
Fosters Fosters is offline
Fosters is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by MBBFord
Nothing some beer and cussing won't fix.
fixed it for ya
Old 02-03-2008, 06:24 PM
mattd17's Avatar
mattd17 mattd17 is offline
mattd17 is starting off with a positive reputation.
"Only thing to make sure of is the possition of the spring, mark the front of the spring before you take it out, then put the marked part back faceing up front."
the spring should only go on one way, since the bolt pattern for the top spring cap is not an even 120 degrees inbetween bolts, and the cap will only sit correctly on the spring one way.......
Old 02-03-2008, 08:38 PM
MBBFord's Avatar
Quote:
Your right, the whole assembly can only go it one way.... I was referring to the spring when it was taken off the shock.... to put everything back just like it was(I didn't on one side and had a shudder sound every time I hit a bump, so I went back and fixed it up, and no more shudder).
Old 02-04-2008, 07:05 AM
For those that changed the front shocks, what spring compressor did you use? I have looked at them, harbor freight brand scares me a bit, I was looking at the Powerbuilt one, instead of having hooks it uses U bolts. Looks a little more safe. Then again for changing just stock shocks I wouldnt think you would need to compress all that much versus one that might be adding a spacer at the top.
Old 02-04-2008, 10:07 AM
MBBFord's Avatar
If your just adding the leveling kit on top of the coil over shock assembly, then you don't need the spring compressor.
I rented a spring compressor from Auto Zone that had the hooks that would grap the spring from the outside of the coil.(they tried to give me one for the inside... can't use that one, the shock is inside). Worked good, and when I brought it back, I got a full refund on the rental.
Old 02-04-2008, 08:44 PM
mattd17's Avatar
the one that i used just had the outside hooks, and also came with a "safety kit".... just a extra set of hooks to hold the main hooks into the spring so it wont (or shouldnt) pop off. and yes, if you are just replacing stock struts to the same size, you wont need to compress it much... now, when i installed my 6" RCD strut.... that was SCARRY !!!! i had to compress them so much that the main screw shaft on the compressor was actually bending....... these compressors afterall are nicknamed "widow-makers" for a reason !!!!
Shock absorber Powerstoke73 1999 - 2003 7.3L Power Stroke Diesel 3 08-03-2014 08:23 PM
Tightening front shock publiuss Brakes, Steering, Suspension, Tires, & Wheels 3 08-01-2012 03:31 PM
time for shocks Gwilkrrs 6.4L Power Stroke Diesel 7 03-21-2012 04:13 PM
4 Front Shocks? foliot 1987 - 1996 F150 & Larger F-Series Trucks 7 03-09-2009 02:54 PM
front shocks manville 1973 - 1979 F-100 & Larger F-Series Trucks 3 03-04-2005 10:29 AM
Tags
00, 2004, 2005, coil, diy, explorer, f150, ford, freestyle, front, projects, ranger, shock, shocks, springs, struts, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
