Is it possible to DIY the front shocks? - Page 2 - Ford Truck Enthusiasts Forums
Old 02-06-2008, 10:09 AM
db_tanker's Avatar
db_tanker db_tanker is offline
db_tanker is starting off with a positive reputation.
which model spring compressor was being used from Harbor Freight?
This one?
http://www.harborfreight.com/cpi/cta...emnumber=43753
If so, I think I might get it as I could also use it to install the longer springs for the fiancee's Escape.
D
Old 02-06-2008, 10:26 AM
MBBFord's Avatar
MBBFord MBBFord is offline
MBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to behold
I didn't use one like that, but that one might work.....
I used one like this one, but it looked better made:
http://www.harborfreight.com/cpi/cta...temnumber=3980
Old 02-06-2008, 10:30 AM
mattd17's Avatar
mattd17 mattd17 is offline
mattd17 is starting off with a positive reputation.
[QUOTE=MBBFord]I didn't use one like that, but that one might work.....
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=3980[/QUOTE]
this is the same style i used....it worked good, but was still scarry... im sure that it wouldnt be so bad though just doing stock sizes.
Old 02-13-2008, 09:30 AM
black04lariat's Avatar
black04lariat black04lariat is offline
black04lariat is starting off with a positive reputation.
I changed mine out yesterday. It took me a bit longer than expected due to the fact that I have the 2.5 spacer on the front (not autospring so it doesn't compensate for the angle issue). Had to undue the bottom swaybar joint...nothing too special. Just be sure to get a decent spring compressor. I had 2 sets of the harbor freight $10 deals and the center screws bowed on me when I had it compressed so it made for a lovely pucker factor even with the "safety" pins.
Rears were done in 20 minutes. Dont even take the rear wheels off.
Old 02-13-2008, 10:56 AM
great white great white is offline
great white is starting off with a positive reputation.
I changed mine out over the weekend. I had 2 issues while doing the fronts:
1) The original nut at the top of the old shocks (fronts) was rusted and was a real pain pain getting it unthreaded off the old shock rod (spring was compressed).
2) Alignment of new shock to coil over assembly, even though I marked the orientation prior to disassembly somehow the lower shock mount got indexed 90 degrees and wouldnt fit in lower control arm Made sure on the second one it was correct.
Rears are a piece of cake.
I used the tool loaner program at Checkers and got a puller set for the steering arm and upper ball joint and 1 set of spring compressers. Worked well.
Shock absorber Powerstoke73 1999 - 2003 7.3L Power Stroke Diesel 3 08-03-2014 09:23 PM
Tightening front shock publiuss Brakes, Steering, Suspension, Tires, & Wheels 3 08-01-2012 04:31 PM
time for shocks Gwilkrrs 6.4L Power Stroke Diesel 7 03-21-2012 05:13 PM
4 Front Shocks? foliot 1987 - 1996 F150 & Larger F-Series Trucks 7 03-09-2009 03:54 PM
front shocks manville 1973 - 1979 F-100 & Larger F-Series Trucks 3 03-04-2005 11:29 AM
Tags
00, 2004, 2005, coil, diy, explorer, f150, ford, freestyle, front, projects, ranger, shock, shocks, springs, struts, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
