View Poll Results: Which Guage would you install
Oil Temp
0%
Water Temp
100.00%
Voters: 9. You may not vote on this poll
Oil Temp vs Water Temp Guage
on
1 Post
They are both important and this really is a hard choice. I voted water temp simply for the fact that the PCM already monitors oil temp so if you even got autoengiuity or other scanner you can watch that if needed, Also coolant keeps the engine cool as well as the oil. If your coolant starts to overheat an oil temp will still show you it overheating but not as accurately or quickly.
on
1 Post
Originally Posted by MADVAN
I use one gauge for both.
2 sensors with a switch.
Flip of the switch i can see water or oil.
Bill
Bill
Tim could link a diag here. Iam PC stupid!
My van has 2 switches (spdt). I have 1 gauge 140* to 300*.
I use it for oil, water, trans. Not alot of room in a van for gauges.
My stuff is down low. Out of walkby eye view. If i piller mounted gauges i would be replacing them along with a side window weekly!
Bill
Bill
try this. i think it is what you have in mind. I had a volt guage monitoring two diffrent batteries connected like this once.
http://good-times.webshots.com/photo/2360443840102203982aVsCov?vhost=good-times
