97 f250 7.3 replace brake booster?
brake aren't working right. first brake application when stopped or driving worked properly. second application brake pedal gets really hard with little response. replaced master cyclinder no change to braking. bled the brakes farthest to nearest. no change in braking. checked vaccum pump. appears to be good. can brake booster have a slow leak? how can i properly check the booster to see if this is the problem? any other suggestions?
Traveller76
03-16-2013 08:13 AM
Sam86f250
11-30-2012 05:24 PM
uglybus
09-11-2012 09:35 PM
cjf5150
58
11-23-2006 09:20 AM
