Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-25-2008, 11:27 PM
kaboom10's Avatar
kaboom10 is starting off with a positive reputation.
Air/Fuel meter
Has any one used one of these and how do you like it. I want to use it as a tuning tool.
2002 F-150 5.4L 4wd
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-26-2008, 12:22 PM
ReAX's Avatar
Molon Labe
ReAX is gaining momentum as a positive member of FTE.ReAX is gaining momentum as a positive member of FTE.
There are two types, narrow band and wide band. Narrow band is much cheaper and you can tap your stock o2 sensors for the signal. Wide band takes a new sensor and the cheapest wide band system I have seen is $250.
That said, I have a narrow band autometer gauge mounted in a pillar and love it. I do want a wide band gauge for tuning, but I wouldn't run one all the time.
__________________
Too many mods to list, so click here.
-MECP 06/27/08
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
there's a very fine line between not listening, and not caring. I like to think that I walk that line every day of my life.
  #3 (permalink)
Old 01-26-2008, 01:05 PM
kaboom10's Avatar
I love guages and data graphs to interperet. I've read enuff about the ones that tap the stock sensors. It's just another load on the circuit that wasn't calibrated into the parameters. I want to see if mine hunts for stoic and what the a/f ratio for things like driving crowd curves, W.O.T. and decel. Also if I retune the ECU and/or change components I want to see what's happening accurately. I still remember what a fuel curve is supposed to be. 15 years at Holley carb and almost the same at GM. One used f/a and the othera/f to express ratios.
  #4 (permalink)
Old 01-26-2008, 04:27 PM
ReAX's Avatar
Molon Labe
It sounds like you want more than just a guage. Check out innovatemotorsports.com, they have some datalogging stuff that will be up your ally. When sniper ships their recon, that would also be a great way to get this info and if you purchase the Special forces package with datalogging and a wide band interface, you can build your own tunes with a degree of precision.
I am waiting for the datalogging upgrade for my system before I invest in a wide band sensor.
__________________
-MECP 06/27/08
  #5 (permalink)
Old 01-26-2008, 05:40 PM
kaboom10's Avatar
Thanx. I'll give it a try. I even found a shift light I can program for different points. With that I should be able to do some interesting stuff.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
