codes on E4OD trans???? - Page 2 - Ford Truck Enthusiasts Forums
Old 02-04-2008, 10:05 PM
ford trans tech ford trans tech is offline
ford trans tech is starting off with a positive reputation.
89-94 f series with E4OD are equipped with EEC-IV , OBDI to others , memory codes do not have to be cleared for normal operation once the failed or failing component is repaired or replaced EEC-IV only monitors for a failure not performance like OBDII , and most of the PCM,S will clear the memory codes after about 40 warmup cycles if teh concern does not repeat , and when a KOEO test is performed it clears the memory codes automatically , but if the power to the processors keep alive memory is faulty it will erase the codes at every key off cycle but should have a code 15 for it ,if you have an O/D light flashing then it has stored at least one memory code and it can be retrieved if done properly EEC-IV is picky when being tested if the tester isnt operated correctly it wiil erase the codes before they can be retrieved , being you have a 92 model does the speedo ever fluctuate , and see if the cruise control operates and if it shuts off when the light begins to blink if so there could be a problem with the PSOM /programmable speedometer/odometer module , if the cruise shuts off but the speedometer reads normally there is a good chance the PSOM is bad , it relays the speed sensor signal to the processor
Old 05-28-2014, 10:26 AM
beg74 beg74 is offline
beg74 is starting off with a positive reputation.
I know you wrote the question about the e4od tranny a long time ago, but I'm having the exact issue. Did you ever figure out the blinking o/d light?
F250 TCS problem may have just ruined my vacation grey2112 1999 to 2016 Super Duty 2 06-04-2016 01:17 PM
Need help w/various codes, ABS light, speedo/odo not working. GrumpyTroy 1987 - 1996 F150 & Larger F-Series Trucks 0 11-15-2015 01:44 PM
Wiring for Transmission Control Switch (OD switch) on Shift Lever o rips Electrical Systems/Wiring 2 12-09-2009 01:19 AM
C6 to E4OD swap........Complete! David85 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 31 04-27-2008 04:52 PM
92 Bronco codes jonw440 1978 - 1996 Big Bronco 2 02-16-2002 02:58 PM
Tags
1995, 2006, 634, clear, code, codes, continuous, engine, f250, ford, obd1, read, shutdown, sterling, switch, symptoms, tranny, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
