mystery switch - 1977 ranchero
Old 01-25-2008, 06:18 PM
articphoto's Avatar
articphoto
articphoto is offline
What is the joystick like switch for in a '77 ranchero.
Old 01-25-2008, 06:21 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Joystick?
1977/79 Ranchero & 1977/79 LTD II = same dash/same gauges/same switches.
Where is the "switch" = on the door, or the middle of the dash somewhere?
Prolly the Remote Control mirror switch.
Old 01-25-2008, 06:29 PM
articphoto's Avatar
articphoto
its between the wipers and the radio *****, its a 360 degree rotating toggle like switch.
Old 01-25-2008, 06:45 PM
NumberDummy
It's not an electrical switch.
The **** is attached to the right hand outside mirror cable, so the mirror can be adjusted from the drivers seat.
The cable goes from the mirror, passes through the door, runs behind the dash to where the **** appears on the dash.
The ****/cable/mirror came as an assembly only.
If you move the **** and the R/H mirror head doesn't move, the cable is broken.
That was fairly common back then...the cable is paper thin.
