Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 01-26-2008, 07:38 AM
tex25025's Avatar
tex25025 is gaining momentum as a positive member of FTE.tex25025 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by bf250
who in the heck cares who makes the diesel anyway.
Actually there are alot of people(even on this board, although i am not including myself in this) that would buy depending on who makes the diesel. Particularly if the diesel is outsourced to a company that is foreign owned(doesn't make economical sense rather or not the company is foreign or not, but that's what people have issues with, I guess they are still upset about NAFTA and stuff like that). So I believe some would definately base on who makes the engine. A good point would be, if you have someone that has a very solid reputation on making an engine, I would be even tempted to buy it moreso then a company that hasn't made a diesel engine for their trucks in so many years out of a desperate need to make one and get one to market, I would be leary of it. I might still buy it, but not quite as easy. It would depend on more factors then just that of course, but that definately a concern.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
SCT w/Spartan tunes(including FICM tuning)
Fuel Regulated Return
FASS 150/180
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 01-26-2008, 10:03 AM
poppie is starting off with a positive reputation.
nothing run's like a deere or smell's like a John,just kidding,this March our JD 720 gas will be "50" year's old and never been overhauled,not even had the valve's ground,on the other had if it's "RED" leave it in the shed!!!!!!.
  #18 (permalink)
Old 01-26-2008, 11:11 AM
FARM69's Avatar
FARM69 is gaining momentum as a positive member of FTE.
We have a 4020 NA with 16,000 hours on it. Nothing has been done to the engine itself. Although, it's gone through a few clutches in its day. However, I guess this is kind of a useless fact sense it is non-turbo and doesn't see the extreme pressures.
Look at the big rig industry. People buy trucks by what engine the have in them. You can order basically any model with the setup you want.
I still think it would look amazing to see a 7.6l in an OBS truck.
__________________
97' F250HD 4x4 Intercooled Powerstroke 5 Speed LB / Stage II (180cc) Injectors / 10 K / 5er
A-Pillar AutoMeter Cobalts [Boost, Pyro, Water Temp]
4" Straight / EBPV Exhaust Brake / 6637 / CCV / 203 Stat / HX50 (19cm) is being mounted!!
  #19 (permalink)
Old 01-26-2008, 11:19 AM
sneak is starting off with a positive reputation.
Exactly, we've got two 4020s that have been overhauled once each, though I don't know the # of hours on them, I could check on one tonight. The fact is that NO other tractor in it's generation has appreciated as much value as the 4020! At an auction nothing sells as well as a good or rebuildable 4020 either.
__________________
1976 F-250 Camper Special - does not run
1977 F-150 Northland Edition - does not run
2002 F-350 Powerstroke
1996 Ranger 2wd 4cyl manual - daily driver
Diamond-T 5-ton truck - does not run (May recieve a DT466 in the future)
  #20 (permalink)
Old 01-26-2008, 12:35 PM
Here would be a good engine for a project 1/4 ton truck for daily driving.
http://jdpsesc.deere.com/ESComp/serv...langCode=en_US
EDIT: I don't know why it wouldn't let me edit my other post.
__________________
  #21 (permalink)
Old 01-26-2008, 01:39 PM
carlcrout is starting off with a positive reputation.
The 4.5 Liter engines are made in France. JD owns the plant. I have two JD6220's........
  #22 (permalink)
Old 01-26-2008, 02:29 PM
stormyrider is starting off with a positive reputation.
Deere has no engines certified for road use and the ones in the farm tractors are worse for fuel consumption versus horsepower on the market. They have always been fuel hogs and Deere parts come with a extra charge for that green paint. Most farmers a round this area are getting away from Deere and going with IH or New Holland. IH is getting the larger market share.
__________________
2000 F250 4 x 4 77,000 miles conventional cab longbed
six speed manual transmission.
AIS intake, 4" turbo back Magnaflow S/S exhaust
inlet & outlet pyrometers & boost gauge
  #23 (permalink)
Old 01-26-2008, 02:37 PM
Well around here its about 60/40 JD/everything else.
__________________
  #24 (permalink)
Old 01-26-2008, 03:00 PM
tex25025's Avatar
Quote:
Not the little yanmar engine ones in the Deere tractors. I can run the chipper all day long and only use a gallon of fuel.
__________________
Fluidampner
Headstuds
FASS 150/180
  #25 (permalink)
Old 01-26-2008, 03:04 PM
fordfaninIL. is starting off with a positive reputation.
I have an uncle that worked for JD in the corporate office in the quad cities (Davenport, Ia.). A group from JD got to go to Detroit and tour the GM plant in the 80's when JD was considering building engines for GM. He said that it was a joke, the plant was a mess and there where couches and recliners sitting around for people to "relax" on their breaks. He said everyone in the JD group concluded that JD had enough labor issues and did not need to get involved with GM's. As for JD building an engine for Ford, it would just not work on the basis that they only build off road engines. It would take years to develop a highway use engine to meet emissions. And btw, I can list multiple 'red' engines that have made it to the 20k hr. mark and have yet to be touched.
  #26 (permalink)
Old 01-26-2008, 03:21 PM
1. JD's have always gotten better fuel consumption
2. IH hasn't been around since they went out of business in the 80's. It became Case-IH. Now Case-IH and New Holland are the same.
3. JD's have typically been priced about the same as CaseIH or maybe slightly higher. On resale JD's win everytime. Check out some auctions
You are obviously not a farmer, maybe a "wannabe"?
  #27 (permalink)
Old 01-26-2008, 04:01 PM
bf250's Avatar
bf250 is a splendid one to beholdbf250 is a splendid one to beholdbf250 is a splendid one to beholdbf250 is a splendid one to beholdbf250 is a splendid one to beholdbf250 is a splendid one to beholdbf250 is a splendid one to behold
it don't matter who makes it, unless the maker will have control of every aspect from the fuel tank to the tail pipe.
ford is going to request something with a price on it. most likely any company that takes the off up will have to take away the typical quality found in its diesels in order to match the price ford wants. that in itself would remove any of the historic foundation a company has laid for its quality diesels.
plus, without a for light truck use line or department already open, it would take huge sums of money to get up to speed, and that is a lot of money if its going to be competing with someone for a rights contract. plus they would have to recover the r&d costs, to me that would leave too narrow of a profit margin for any major company to consider if they are not already involved in the lgiht truck market.
just my opinion. not saying it would not happen, anyone who does get a contract with ford does have an almost 100% guarantee of truck sales. its just if someone wants to risk the headache.
__________________
current ride - 2003 explorer, 4x4, v8
ford trucks i have previously owned
1972 f250 1989 f250
1995 f350 2004 f250
2006 f250
will get a truck again!
  #28 (permalink)
Old 01-26-2008, 05:24 PM
FARM69's Avatar
There is no way to compare an agricultural used engine (i.e tractor or any off road rated engine) to an engine that would be used on the highway. You might be able to rate it by hp for cylinder displacement or maybe fuel consumption. However, these number do not really mean much. The bottom line is that when the day is done, how much did you use to get the job done. Depending on the application the engine is usually under load created boost. The technology advances that Deere, Case, etc, have gone through in the last 30 years is unbelieveable. Just look during the 70's when air to air came out. The output of these engines sky rocketed. Lets face it, emissions for off road engines are not as strict as on road. I highly doubt Deere would put up the effort to create a beast that would.
Also, I'm not 100% sure on this, but I'm assuming that off road engines are rated for intermediate power instead of peak (which is probably used for our engines).
Everybody knows that green paint is expensive, but i'll tell ya one thing. It all comes down to fuel efficiency when your burning 150 gallons in eight hours day after day.
I'm sure someone that runs irrigation pumps can tell us all about fuel efficiency in agriculture engines.
__________________
  #29 (permalink)
Old 01-26-2008, 05:55 PM
Lead Head is gaining momentum as a positive member of FTE.Lead Head is gaining momentum as a positive member of FTE.
Not quite sure what you mean by that, the diesels in these trucks, ford, dodge, etc..are also used in other applications besides trucks, like pumps, etc.. where they have to hold peak HP or torque day after day.
  #30 (permalink)
Old 01-26-2008, 06:03 PM
tex25025's Avatar
The 3 deeres that I have are rated by peak.
__________________
Fluidampner
Headstuds
FASS 150/180
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
