mystery switch - 1977 ranchero - Ford Truck Enthusiasts Forums
Old 01-25-2008, 06:18 PM
articphoto articphoto is offline
articphoto is starting off with a positive reputation.
What is the joystick like switch for in a '77 ranchero.
Old 01-25-2008, 06:21 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Joystick?
1977/79 Ranchero & 1977/79 LTD II = same dash/same gauges/same switches.
Where is the "switch" = on the door, or the middle of the dash somewhere?
Prolly the Remote Control mirror switch.
Old 01-25-2008, 06:29 PM
its between the wipers and the radio *****, its a 360 degree rotating toggle like switch.
Old 01-25-2008, 06:45 PM
It's not an electrical switch.
The **** is attached to the right hand outside mirror cable, so the mirror can be adjusted from the drivers seat.
The cable goes from the mirror, passes through the door, runs behind the dash to where the **** appears on the dash.
The ****/cable/mirror came as an assembly only.
If you move the **** and the R/H mirror head doesn't move, the cable is broken.
That was fairly common back then...the cable is paper thin.
Tags
1977, 1977ranchero, dash, ford, knob, rancher0, ranchero, sale
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
