Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-25-2008, 03:30 PM
NoShot is starting off with a positive reputation.
'87 460 to EFI 400?
It's time to change out the engine, I done a bit of looking and I sure all my answers are posted here somewhere, but can't seem to find them all in one place.
So here goes, I would like to swap out my 87 460 to a fuel injected newer engine, 400 maybe even a 351m. what years would be the best to look for and can I find a new/rebuilt one with all the FI, and computer controls with wiring? I would rather not look to a wrecking yard for the engine itself. Also, do I need to swap fuel tanks to allow for in tank fuel pumps or can the stock ones accept the pump?
Stats as is now,
87, 460 carburated(TBI ?), c-6 trans, dual exhaust, cruise, Air cond. front end Hub to Hub less that 300 miles, trans-case less than 500 miles, tranny about 8K on it
The truck itself is in Excellent shape inside and out, the engine and engine controls are just really tired, would rather spend 5-6K on a swap than 20+K on a newer truck. Mechanical and fabricating abilities are no problem.
Thanks for time Gentlemen..
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-25-2008, 07:15 PM
Kemicalburns's Avatar
Kemicalburns is gaining momentum as a positive member of FTE.Kemicalburns is gaining momentum as a positive member of FTE.
the 351m and 400 never came efi nor did they get produced into ford trucks after 85-86. best bet would be to rebuild what you have and go with efi on the truck. there are plenty of 88+ trucks with efi equipped 460's at the yards to source parts
__________________
94 XLT 5.8/E4OD
6"ProComp Stage II 35x12.5x15 BFG MT's ,
4.88 gears f/r
installing soon: JBA shorty, Bassani Y pipe, Edelbrock efi truck intake, , aussie front/rear
88 (Rolled)
http://www.supermotors.org/registry/vehicles/detail.php?id=4158
  #3 (permalink)
Old 01-25-2008, 08:46 PM
merlynr is starting off with a positive reputation.
Ford Trucks with possibly a 460 1976-1997
__________________
97 F250 4X4 7.5
71 F350 dump 360
99 Explr XLS 4.0
05 Mustang GT 5 sp
73 Mustang cpe
71 Mustang cpe
65 Mustang fastback
  #4 (permalink)
Old 01-26-2008, 04:28 PM
trinogt is starting off with a positive reputation.
Go to the 460 forum instead of this one, because you will find the info from all years of the 460 to answer all your questions. A newer efi 460 might be what you are looking for, but from what I am hearing, if you want a lot of performance, the carburetor 460 is better because there just aren't many parts available for efi 460's to improve them.
__________________
Mark in FL
restoretherepublic.com
  #5 (permalink)
Old 01-28-2008, 09:52 PM
92f150I6's Avatar
92f150I6 is starting off with a positive reputation.
You could look into rebuilding your 460 and swapping in an after market fuel injection system.
__________________
2003 F250 SD 4X4 5.4L 4:10 Arizona Beige
1987 Mustang GT
A bunch of motorcycles, other cars, and a Quad.
  #6 (permalink)
Old 01-30-2008, 12:56 PM
*********- High Plains
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
It wouldn't be that hard to swap in another 460, I like Ford Multi Port EFI, its far better than any carburetor could ever claim to be. I'd look for a donor truck, 89-97, and rebuild the motor out of that and keep driving yours, then you can snag all the good parts from it and still sell it in the end to make a few thousand back.
  #7 (permalink)
Old 02-06-2008, 09:47 AM
monckywrench is gaining momentum as a positive member of FTE.monckywrench is gaining momentum as a positive member of FTE.
"rebuild the motor out of that and keep driving yours"
THAT is the voice of wisdom where projects are concerned.
  #8 (permalink)
Old 02-07-2008, 06:35 PM
Sometimes I have a brilliant flash...
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
