Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
  #1 (permalink)
Old 01-25-2008, 09:28 AM
blakrodder33 blakrodder33 is offline
Garage is empty, add now
blakrodder33 is starting off with a positive reputation.
Exclamation '92 Ford explorer burning oil?
I just bought a '92 ford explorer and gave it a tune up. I only put about 400 miles on it and I am putting the second qt. of oil in it. I haven't seen any leaks at all and it isn't puffing out blue smoke. I heard I should Check the spark plug from cylinder #5 for crusty deposits. Apparently the lower intake manifold gasket has a habit of leaking oil into that cylinder. Any body have any other ideas before I tear into this thing?
  #2 (permalink)
Old 01-25-2008, 09:59 AM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
Check the plugs and do a compression test, Post results
  #3 (permalink)
Old 01-25-2008, 10:14 AM
mrshorty mrshorty is offline
mrshorty is gaining momentum as a positive member of FTE.
this is a fairly common problem on the OHV. Usually it can be fixed by simply torquing the lower intake manifold bolts back up to spec. I remember the first time I did this, they were pretty loose. It can be done without taking anything off, though many like to remove the upper intake. Before you tear it all apart, I would suggest just grabbing a torque wrench and a 10mm and 13mm socket and see if the bolts are just loose.
__________________
'87 Bronco II XLT 4x4 & '92 Explorer XLT 4x4 & '98 Chev Suburban K1500 SLT 4x4
  #4 (permalink)
Old 01-25-2008, 01:02 PM
I already did a compression test and everything was fine
  #5 (permalink)
Old 01-25-2008, 01:03 PM
I did torque down the intake it was a little loose but not too bad i'll see how that works.
Tags
1994, 91, 92, burnig, burning, burns, engline, explorer, exproler, ford, intake, leaking, oil, ranger, why
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
