Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-25-2008, 08:53 AM
LUMBERMAN is starting off with a positive reputation.
Pre purchase inspection
Im thinking of getting an 03 7.3 or 6.0 dually F350. but I want to make sure I do every thing in my power not to get a lemon. Anybody know if there is any type of mobile mechanic service that will check the truck "soup to nuts". Or is alot of a veicle purchase just the luck of the draw?
__________________
1999 F250SD BLACK AND TAN EXTCAB ,7.3PSD ,SRW, LNGBD, AUTO ,LARIET TRIM ,MFG 1/99 ,TUBEGRILLE INSERT 4X4 RANCHO 9000 SHOCKS, AIRLIFT,5700SERIES AIRBAGS,HADLEY SOLENOID ATTACHED TO AIR TANK WITH OLD FREIGHTLINER AIRHORNS MOUNTED ON FRAME RAIL ,4"LIFT ,LANCE#835 TRUCK CAMPER
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-25-2008, 10:47 AM
stormyrider is starting off with a positive reputation.
The 6.0 engine had injector problems, head gasket issues, problems with the variable pitch turbo blades and acuator. It could be running like a top when you look at it and puke the day after you buy it. I would look real hard for a 7.3 engine unless you are real confident that the 6.0 you are looking at is one of the few with out issues.
__________________
2000 F250 4 x 4 77,000 miles conventional cab longbed
six speed manual transmission.
AIS intake, 4" turbo back Magnaflow S/S exhaust
inlet & outlet pyrometers & boost gauge
  #3 (permalink)
Old 01-25-2008, 12:41 PM
miller_feed's Avatar
Hook it, I'll pull it.
miller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to behold
Quote:
Here is a guide for buying a used diesel. http://www.ford-trucks.com/forums/52...questions.html
Good luck.
__________________
RICK, PAA MEMBER #4
2001, F-350, DRW. CC. LWB, 4X4, LARIAT,
MODS: 6637 W/Pete's filter cover, BTS-VB, DP-TUNER- stock, 40t, 60t, 80e, 140s, HI, OBA, 203*, billet housing, IH bolts, MBRP 4" SS, Isspro 3 gauge kit, Zoodad, Foil delete, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler. For now.
Jim, Roland, Will, JD? I want to go somewhere.
  #4 (permalink)
Old 01-28-2008, 06:48 PM
randomhero1172 is gaining momentum as a positive member of FTE.randomhero1172 is gaining momentum as a positive member of FTE.
Quote:
Uh-oh! put on your flame suit. some 6.0 guys wouldnt take kindly to that comment lol but i agree! 7.3 is the one for me!
__________________
- Joe
2002 f-250 CC long bed 7.3 PSD - 295,000mi: 6637, Zoodad, Foil Delete,Silverstar Ultras, CCV, 5" MKO Strait Pipe, Cab Lights, WW.
NEW!!!! - 1990 f-350 dually 7.3 IDI 12ft Alum. Boc. 197,000. A little shaky
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
