460 EFI MAF CONVERSION +SUPERCHARGER - Ford Truck Enthusiasts Forums
Old 12-30-2001, 03:59 AM
rah jim3 rah jim3 is offline
rah jim3 is starting off with a positive reputation.
I just came across a pretty neat ECU conversion specialist website www.racesystems.com They have a 460efi truck fitted with a mustang 5.0 HO ecu w/MAF custom tuned to accomodate 36lb inj,supercharger,increased displacement,etc.That truck made a whopping 500+rwhp while maintaining 15+ freeway miles ??????? I'm gonna check them out,this just be the ticket for those of us that have the MAF,and the mileage blues.
Old 12-30-2001, 12:41 PM
ddestruel ddestruel is offline
ddestruel is starting off with a positive reputation.
Welcome to the Club, Mike Schaffer is doing the same thing, and i originally started out doing the same thing, i have a string here at FTE that covers all the trials and errors that i went through in converting to the MAF system for my 460.
http://www.ford-trucks.com/dcforum/80_96/4544.html#23
Check it out the information should be helpful. Do you already have a MAF equipt 460? what modifications have you done? where are you at in the modified 460 EFI game? Good Luck
Dusty
F-250 now 350 4x4 ext cab SB Green Monster mass air 460 w/5spd conversion 205 T-case 4.11 gears, Doug Thorleys and converted 33 gallon bronco rear tank. Soon to be a 5.9L cummins diesel 5spd.
Old 01-06-2002, 03:49 AM
Thanks for the highlight,Dusty.Any additional hints or information is greatly appreciated here.I tackled my 97 460 engine swap as well as the grueling task as swapping the entire wiring harness,R134A AC,etc.I started 5 days ago,got the majors done,just need to reloom the wires in the cab and engine compartment.Decided to swap the harness because,I took note the 97 has the 3G? alternator,instead of modifying the harness,eliminating possible wiring mistakes or even worse, a vehicle fire.Right now I'm just doing a preliminary on the M.A.F. and SUPERCHARGER.I used to have a poor habit of just rushing into things,costing both time and erroneous spending.Main reason is that I want to do the conversion right the first time with minimal corrections.So right now ,I'm just doing my homework and checking with specialty shops for product highlights and experiences.Planning to install a VORTEC supercharger,according to the listed power gains,wasn't that impressive especially factoring in the price factor,thats why I'm looking into MAF and possible ECU conversion,that way I may be able to run a much more aggressive fuel,timing curves,camshafts,as well as losing the ill fated MAP sensor if possible.How is MAF system conversion on your truck performing so far?,And how the system displays on a basic ECU scantool,such as SNAP-ON MT-2500 scanner or equivalent?I may do the actual MAF+SUPERCHARGER this summer or when time permits.I utilized my vacation time to do the engine swap.(so much for vacationing)THANKS AGAIN:P
Old 01-09-2002, 08:54 PM
I dont remember if you said you had the E40D or a five speed, Mike Shaffer is going a different route, and is selling that MAF kit i used you might look him up here at cfte and email him, his call name is Shami02.
As to the MAF kit it worked well i did have to change the MAP to a BAP. The overlay is simple and using the mass air meter voltage regulator allowed me to fine tune the system. It does still use the diagnostic plug in for the ECC. I had a few glitches with this but most of it could be attributed to the fact that the MAF kit was for off road use only and so some wires were left out.
Hope this Helps
Dusty
F-250 now 350 4x4 ext cab SB Green Monster (Used to have)205000 miles, Mass air 460 w/ performance heads, E40d to 5spd conversion, 205 T-case, 4.11 gears, Power-Lok equipt dana 60 front, Doug Thorleys and swapped in EFI 33 gallon bronco rear tank. 33's on 16x8" Outlaw II's, Truck is destined to be a 5.9L cummins diesel 5spd.
Old 01-10-2002, 06:40 AM
rabidranger's Avatar
rabidranger rabidranger is offline
rabidranger is starting off with a positive reputation.
Old 09-21-2012, 05:52 PM
Blueoval_boy_64 Blueoval_boy_64 is offline
Blueoval_boy_64 is starting off with a positive reputation.
I'm in the middle of doing a MAF swap to my 460 with the V-1 supercharger on it. Hoping to hear it run again soon!!
<a href="http://s568.photobucket.com/albums/ss122/Blueoval_boy_64/?action=view&amp;current=IMG_20120921_142728_zps65 9f2286.jpg" target="_blank"><img src="http://i568.photobucket.com/albums/ss122/Blueoval_boy_64/IMG_20120921_142728_zps659f2286.jpg" border="0" alt="Photobucket"></a>
460 efi custom chip mroth2008 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 0 07-21-2014 03:31 PM
95 460 E40D Califonia MAF Conversion arod1256 1987 - 1996 F150 & Larger F-Series Trucks 8 11-04-2013 09:09 PM
1990 460 ecu w/E4OD What ecu code to look for UNTAMND 1987 - 1996 F150 & Larger F-Series Trucks 7 07-24-2013 01:47 AM
MAF EFI 300 L6? SoCar72 1987 - 1996 F150 & Larger F-Series Trucks 6 02-02-2012 12:09 PM
460 EFI hp mods...Anything out there Dickc Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 19 04-01-2003 02:23 PM
Tags
460, air, conversion, converting, ecu, efi, fi, ford, fuel, injection, maf, map, mass, supercharged, supercharger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
