Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-24-2008, 10:34 PM
herman391's Avatar
herman391 is gaining momentum as a positive member of FTE.herman391 is gaining momentum as a positive member of FTE.
Supercharger or turbo?
So we were sitting around at work today chatting about cars like we normally do and the topic came around to diesel engines. One guy said that turbo's are the only way to go with diesels. Another guy said Superchargers were just as good if not better for diesels. I've never seen a diesel with a supercharger on it but then again I'm not big into the diesel side of things.
What do you guys have to say?
__________________
Steve-AKA herman391
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-24-2008, 11:57 PM
BLK94F150 has a very good reputation on FTE.BLK94F150 has a very good reputation on FTE.BLK94F150 has a very good reputation on FTE.
Turbo. Power from waste. How can you argue with that?
Mike
__________________
2000 F150 5.4 4R70W 4x4 Supercab 3.55 gears
  #3 (permalink)
Old 01-25-2008, 01:16 AM
Pocket's Avatar
Pocket has a great reputation on FTE.Pocket has a great reputation on FTE.Pocket has a great reputation on FTE.Pocket has a great reputation on FTE.
If supercharging a diesel were really better than turbo, we'd see it on our trucks and semi's by now.
__________________
Curtis
2002 F-250 PSD
Best time: 15.3 @ 86.8 MPH at Bandimere - 9/10/08
  #4 (permalink)
Old 01-25-2008, 01:17 AM
884x4broncoII is starting off with a positive reputation.
i agree with blk94 a super charger uses hp to make hp turbos use the exaust to make hp, turbo's are better, but then again superchargers have no lag so a super charger would give you better throttle responnse. but powergains/economy turbo is the only way to go
  #5 (permalink)
Old 01-25-2008, 01:45 AM
theblueox is starting off with a positive reputation.
alot of the older semi's used super chargers. If I remember right the early drag racers took the 6-71 super chargers off of diesels and modified them to work on the hemis.
  #6 (permalink)
Old 01-25-2008, 06:24 AM
origcharger is gaining momentum as a positive member of FTE.
Quote:
Those superchargers were on Detroit Diesel 2 stroke engines, they would'nt run without them as there was no intake stroke to draw in a sufficient amount of air. The 6-71 designation was actually the identifier of the engine the blower came off of, the 6 stood for six cylinder and the 71 for seventy one cubic inches per cylinder.
__________________
Powerstroking Seven T444Es, one VT365 and one 6.0. Also four DT466s, one DT360 and a Mercedes MBE906.
I'm doing my part to reduce food imports, control rising food costs and help feed the children, my trucks run on 100% petroleum diesel. What are you doing?
  #7 (permalink)
Old 01-25-2008, 06:37 AM
Lead Head is gaining momentum as a positive member of FTE.Lead Head is gaining momentum as a positive member of FTE.
Yeah, them detroits didn't have super chargers, they called them "induction blowers", and they were actually considered naturally aspirated.
  #8 (permalink)
Old 01-25-2008, 09:53 AM
Quote:
Yep, and some of them had turbochargers on them also to feed the "Induction blowers".
__________________
  #9 (permalink)
Old 01-25-2008, 10:25 AM
rbaker6336's Avatar
rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.
cummins also used superchargers years ago,they added about 100 HP
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install
DooDad???=(dfuser ram air)
'98 Grand Cherokee
'86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
  #10 (permalink)
Old 01-25-2008, 10:41 AM
stormyrider is starting off with a positive reputation.
I have seen a detroit diesel on a generator set that had twin turbo's and a supercharger on it. superchargers supply low end power for when you first get a load but require power from the engine to drive them. Turbos don't give much boost until you have already loaded the engine and are getting some exhaust gas volume, this is the source of turbo lag. turbo's are making use of the waste heat in the exhaust and don't rob any power from the engine to operate so they are the more energy friendly way to go and are also cheaper and weigh less then the superchargers.
__________________
2000 F250 4 x 4 77,000 miles conventional cab longbed
six speed manual transmission.
AIS intake, 4" turbo back Magnaflow S/S exhaust
inlet & outlet pyrometers & boost gauge
  #11 (permalink)
Old 01-25-2008, 02:27 PM
Joshua0606's Avatar
Joshua0606 is starting off with a positive reputation.
The saying "It takes power to make power" is not true, for example turbos and NOS.
__________________
Josh
'05 F-250, CC, King Ranch, 6.0 PSD
- 4" turbo back
- Spartan tuned SCT
JOIN THE LOUISIANA CHAPTER, CLICK HERE
LA CHAPTER PHOTO ALBUM
  #12 (permalink)
Old 01-25-2008, 02:57 PM
rob_nc is gaining momentum as a positive member of FTE.
Quote:
You are partially correct. Turbos do require power to operate, in the form of heat energy. They don't rob any power from the crankshaft is where the difference is.
  #13 (permalink)
Old 01-25-2008, 04:03 PM
sneak is starting off with a positive reputation.
Quote:
We could chase eachother around forever, but the way I would describe it is:
A supercharger is belt driven off of a crankshaft pully, it draws about 35-50% the extra torque or power it adds to its naturally aspirated cousin.
A turbocharger uses energy that would otherwise be wasted, using an exhaust turbine. There are no gears or lots of rotating mass to rob torque anywhere in a turbocharging system. That is why they say it gives you "free" power.
The problem with calling it free power is that in order to produce boost, you must create back pressure to drive the turbine. The loss of efficiency with a turbo is generally much smaller, generally being less than 10% loss due to the backpressure created, and less than 5% on some well engineered industrial turbocharged setups.
__________________
1976 F-250 Camper Special - does not run
1977 F-150 Northland Edition - does not run
2002 F-350 Powerstroke
1996 Ranger 2wd 4cyl manual - daily driver
Diamond-T 5-ton truck - does not run (May recieve a DT466 in the future)
  #14 (permalink)
Old 01-25-2008, 05:57 PM
SUPERDUTY_untouchabl's Avatar
SUPERDUTY_untouchabl is gaining momentum as a positive member of FTE.
Why not both?
__________________
-Josh
04 F150 4.6l Gryphon Powered 2wd reg cab XL 3:55 LS SISO Flowmaster S40 NCD Customs 2.5" Leveling Kit Burner High Power Fog Lights
  #15 (permalink)
Old 01-25-2008, 06:10 PM
Because unless you have a two stroke and need it, it's more efficient to run one, or two, or three turbo's.
Now if you're going to be street racing you could use both, and it might be justafiable.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
