coats 2020 tire machine - Ford Truck Enthusiasts Forums
Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Old 01-24-2008, 10:16 PM
FM FordFan's Avatar
FM FordFan FM FordFan is offline
FM FordFan is starting off with a positive reputation.
At an upcoming auction there is a Coats 2020 superstar tire machine. From the pictures it looks well used. Does anyone know if Coats tire machines are any good?
Old 01-25-2008, 01:50 AM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
If you have the room for it, it's not a bad machine. You can get covers for the bar ends to keep from scratching aluminum rims.
Old 01-25-2008, 09:38 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
They will last a long time, and are pretty handy to have. I like some aspects of the over the top mag machines, but the old style machines like that are pretty handy too. I like the ability to break both beads at the same time...
Old 01-28-2008, 06:25 AM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
I used an old 100% manual changer for a long time. I was at the right place at the right time and got a 2020 at a super deal ......we got a new changer, haul this one off for us? Oh how I LOVE my 2020!!!!
For a business the new over the top changers are the cats a$$ but at $3-4K my backyard shop will never see one. My friends all like my 2020 too!
Old 01-28-2008, 08:08 PM
FM FordFan's Avatar
How easy are they to use?
Old 01-28-2008, 09:14 PM
fellro86's Avatar
Basically, put the rim on the center post, spin the holding piece on, pull the bead breaker over the top, then push the pedal to break the beads, put the bead breaker aside, and then get the bar under the bead, place on the flat part of the center post, push the pedal again to peel the tire off the rim, repeat, tire is off. To put the tire on, you place the bar on the rim and center post, put the tire on to peel on, and press the pedal. Not too bad.
Old 01-28-2008, 11:59 PM
Ford_Six's Avatar
I have many, many hours on these machines. Their only limitation, for me anyways, is the overall tire size. They can only fit about a 36" tire, but that isn't a big deal in most shops. I deal mostly with 36-42" tires, with the exception of he occasional car tire just for personal stuff. For the time being, I do it all by hand.
Old 01-29-2008, 01:49 PM
pitrow pitrow is offline
pitrow is starting off with a positive reputation.
They don't do well with exceptionally wide tires either. I have an older one that we use for our race car tires. It could probably stand to be overhauled, as it's a little underpowered for my taste, but like I said that's probably because it needs to be cleaned and overhauled. I have problems breaking beads on the 12" slicks and sometimes it's hard to get it to peel the bead over the wheel rim. I've often gotten the bar stuck between the bead and the wheel and it doesn't have enough power to go forward or back. I have to smack the bar up off the center post with a big hammer to get it free, and then start over. I think this is just a problem with the slicks because they have such a stiff bead, I only had this problem with a few bigger truck tires, but for most passenger tires it's been fine.
Old 01-29-2008, 05:38 PM
fellro86's Avatar
You can get that with the overhead machines too. Line pressure also will be a factor there as well.
Old 01-29-2008, 08:48 PM
Ford_Six's Avatar
Unless it's an electrically powered machine.....
For the air ones, you can install a larger air cylinder, change the pivot point of the cylinder, or increase the line pressure. Make sure to lube everything well, since it's probably never been done since it was new.
Old 02-10-2008, 11:05 AM
ncranchero's Avatar
Quote:
ANY powered tire changer is easier to use than an old manual style or the old hammer and tire spoon method ! ! !
Did you get the Coats??? I have a parts manual for it if you need it.
Old 02-11-2008, 07:50 PM
FM FordFan's Avatar
The auction is coming up in a couple of weeks. I will let you know if I get and what it goes for.
Old 02-17-2008, 09:24 PM
kfosburg kfosburg is offline
kfosburg is starting off with a positive reputation.
Looking for Coats 2020 manual
Hi,
My father in law just gave me his coats 2020 tire machine and I'm looking for a manual for it. I found a parts list so far but would like to find a PDF of the actual manual.
Also, where would I get those covers to protect alloy rims?
Thanks in advance,
Karl
Old 02-17-2008, 09:39 PM
Ford_Six's Avatar
Welcome to FTE-
Here's a parts breakdown and general maintenance manual:
http://www.aescosc.com/pdfs/2020%20TIRE%20CHANGER.pdf
You should be able to get the protectors from that same company or from Discount Tire/America's Tire, or Big O Tires.
Old 02-19-2008, 09:21 PM
FM FordFan's Avatar
I went to the auction today. The Coats Machine went for $425.00. I thought it went high for the condition it was in.
starting a new project whiskey runner 1967 - 1972 F-100 & Larger F-Series Trucks 2 07-23-2015 12:58 PM
coats 4040A tire machine manuals tjc transport Garage & Workshop 11 04-23-2011 12:15 PM
Exhaust Manifold Gasket ChunderDownUnder 1999 - 2003 7.3L Power Stroke Diesel 13 06-28-2009 06:24 PM
Clear Coat Peeling off Rim....Helllp PsD007.3 1999 - 2003 7.3L Power Stroke Diesel 7 03-16-2009 04:39 PM
How Big of Tires can a Dana 50 TTB handle fordmudrunner2020 Clutch, Transmission, Differential, Axle & Transfer Case 4 02-01-2004 10:03 AM
Tags
20, 2020, 30, changer, coats, machine, manual, older, oregon, parts, pedals, photos, specs, tire, vintage, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
